Nav in 2006 - Keeps speed record?
Discussion in 'Gen 2 Prius Technical Discussion' started by osiris12, Nov 2, 2006.
  1. osiris12
    osiris12 Owner of 3, yes three priuses
    119
    Upstate NY
    Hi All,
    Just wondering if my 2006 Prius stores my speed and location inside its diagnostic computer.
    I've been reading this
    Britain is becoming 'Big Brother' society: report
    http://news.yahoo.com/s/afp/20061102/wl_uk...tv_061102190511
    Just wondering...
  2. qbee42
    3,080
    Some speed and other control information is stored for a short period of time. This can be accessed in the event of a crash.
  3. osiris12
    119
    Upstate NY
    <div class='quotetop'>QUOTE(qbee42 @ Nov 2 2006, 08:55 PM) [snapback]342952[/snapback]</div>
    Thanks qbee42, So it is tracked. Does it keep track of location of the speed.
    Is there a way to erase that data
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Locations are not recorded. Black boxes are now common on most, if not all, new motor vehicles.
    Do a Google search for: "Automobile Black Boxes."
    Here is an example:
  5. Stringmike
    Stringmike New Member
    77
    In the USA, however, the black box and the information in it is the property of the vehicle owner. It can only be obtained by others by the use of a search warrant or similar legal instrument.
    I should also note that cell phone records have been used to see if they were being used at the time of an accident and may have been a contributory cause. (Cell phone use while driving is pretty equivalent to driving drunk).
    Mike
  6. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Stringmike @ Nov 2 2006, 08:39 PM) [snapback]343018[/snapback]</div>
    Not completely accurate. Legislation regulating the use of the EDR recordings exists in only about one quarter of the states. California was the first state to regulate the use of such data with a law that was enacted in 2004.
  7. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< Hello osiris12
    You don't say WHERE you are or which Prius you're driving... if, indeed, you ARE driving a Prius. Knowing your location, and model of Prius are always helpful when responding to questions.
    Want to "erase" the data? :D Have you been speeding and want to get rid of the evidence? :D
  8. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    to the best of my knowledge, the "black box" does not integrate with the nav unit. instead, it has a short term memory, which is only capable of saving data for a a few seconds, maybe a minute. The data it records, i believe, is speed, rotation of the steering wheel, pressure applied to gas and brake pedals, and probably some internal data (such as traction control or ABS activated, etc).
    They key point is that it's short term - no one can go to your car and tell how fast you were driving last week from the data in the "black box". and while explicit legislation hasn't been drawn up in every state, the information is erased fairly quickly unless the car senses and accident.
    So you don't have to worry about it having a recording of all your illegal driving habits (speeding, illegal U turns, etc) :p
  9. Stringmike
    77
    True - legislation has been enacted in only a number of states.
    However, my main point was that the car and any recording devices in it are the property of the owner and proper legal procedures should be used to acquire data from it. This is true in all US States since property rights are (supposedly) guaranteed by the Constitution. There have been cases where police have obtained data without the permission from the owner, such as when a vehicle has been impounded as part of an investigation. The latest regulations are to remove any possible ambiguity on ownership of data and access by authorities to it.
    Mike
  10. osiris12
    119
    Upstate NY
    <div class='quotetop'>QUOTE(Stringmike @ Nov 3 2006, 03:27 PM) [snapback]343428[/snapback]</div>
    Thanks everyone for your insight (no pun intended). I'm not a speeder but value my privacy and this info puts my mind at ease for now. It seems that Briton is becoming a police state rather quickly. I'm sure the states will not be far behind.
  11. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I'm not familiar with the Prius nav. but my Garmin Nav units include a "trip computer" function that runs all the time. They record max. speed among many other things, and will keep that reading until you manually erase it. I use it to remind myself to drive carefully. It's amazing how fast you can go when passing someone on a busy two lane road (135 km/hr seen on the Garmin but not by me as I was concentrating on the oncoming vehicles)! Not in a Prius though. ;)
