2020 Prius Prime PCV valve location
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Hoan, Nov 16, 2021.
  1. Hoan
    Hoan Junior Member
    Los Angeles
    2020 Prius Prime
    Can someone post photos for the PCV location. I'm trying to change it, and install an oil catch can. Thanks!
  2. DOHCtor
    DOHCtor Member
    162
    94
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    On the on the PCV plate, at the front side of the block, directly under the intake manifold. :)
  3. Mendel Leisk
    41,889
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    This thread and @Raytheeagle photos are maybe helpful. Personally, I don't think it is necessary, and I don't even know what it does.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Here's the thread on the install of the catch can on our 2019 Prime:):
    Oil Catch Can | PriusChat
    Im about to do the 50k mile oil change, and I'll find out how much I've caught since 40k miles;).
    But my EV ratio has gone up, so the engine runs less:whistle:.
    Data forthcoming (y).
  6. Bill Norton
    Bill Norton Senior Member
    2,218
    745
    MONW, Ks.
    2019 Prius
    L Eco
    So how many miles are on the engine oil at this 10k mile oil change?
    Is the 'forthcoming data' an official Oil Analysis?
    They don't cost much!
    Probably less than what you are spending on the oil and filter.
    The report would be interesting, no?
    I used to get a kit at a heavy equipment shop for ~$22. It's a small jar and a prepaid envelope.
    MTN likes this.
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    The data forthcoming refers to the amount caught by the catch can;).
    Since this thread is about catch can installs, I'm trying to stay on topic with pertinent info :).
    If you wanna talk oil analysis, I'll gladly save some and I'll get you my contact info so you can pay for the analysis:whistle:.
    Given I will only have about 2500 miles on the oil based on my EV to HV ratio and I use Pennzoil Pure Platinum as well as use BG Products MOA, I don't see the need to analyze to know the oil is fine and could run longer (y).
    Bill Norton likes this.
