Does this happen with a lot of wheels?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Wraiththe, Nov 15, 2021.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Try replacing an Alloy wheel - damaged one of these decades ago - can't remember the exact price, but would be today's equivalent of $1000 a rim (genuine). Fortunately, I was able to get it straightened. They were nice rims - except a pain to clean!!!
  2. dmh1026
    dmh1026 Junior Member
    25
    Estero, FL
    Four Touring
    Mine’s doing the same thing and hasn’t been near salt water. Poor paint on the plastic parts!
  3. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    I have the same problem, but on the upgrade wheels (the ones with 10 double spokes in dark chrome), the chrome is coming off nearly the entire rim at all 4 points, much like the "paint" on those. I drive mostly in Ohio, where some salt is used on the roads, less frequently lately as we haven't gotten much snow the last few years.
    It's not a safety concern, merely cosmetic.
  4. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    Not sure this is your wheels: Chrome plated aluminum is a bad choice. If anything gets between the metals it causes a catalytic reaction that cannot be stopped and the chrome will continue to peel off. It can be slowed down... but it will still eventually continue. This is not a safety concern.. but it can get into the areas where the tire bead seals against the wheel... which will cause your tired to deflate often. I had a chrysler like that and thought someone was letting the air out of my tires now and then. Those wheels were $480 to over $600 a piece 8 years ago... $150 used.
  5. dmh1026
    25
    Estero, FL
    Four Touring
    Same thing happened to my 2017 wheels. The silver plastic parts are cheap junk. I can order black replacement pieces. The wheel has to come off the car to replace them.
