Check oil level
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Peng Xiao, Jan 2, 2022.
  1. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    It's not easy to read the oil level, especially just after oil change, the oil color is so light. And the dipstick tube is curved, I think it touched the tip to make the reading even harder.
    Any suggestion?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Leave it sit outside of the tube for 5 minutes and then insert it;).
    I also turn it over to compare the different sides of the dipstick (y).
  3. Mendel Leisk
    41,850
    The dipstick seems to draw oil up the tube, when you first remove it, messing up the dipstick when you wipe and reinsert for the check; that 5 minute wait gives the drawn up oil time to drain back down.
    don_chuwish and Raytheeagle like this.
  4. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    If you don't get a good read the first time, try try again!
    One side is usually good and the other is not, most of the times I've read the dip stick !
    flip it (the dip stick) around a few times ! - get to know what it always looks like in your car ! - use a bright flashlight ! - change your own oil and watch as it starts to show in the stick and document how many quarts you put in at both holes ! (edit did you prime the filter or put it in dry) - than read it again in a week !
    best of luck, it ain't a (No-brainer) !
  5. Mendel Leisk
    41,850
    ^ Here here. It's tricky, but it's not impossible; get familiar with it.
    Whenever I've changed the oil, I let it drain good, reinstall drain bolt, put in 4.2 liters (4.4 US quarts), and don't second-guess it. Checked a few days later, first thing in the morning, it's 3~4 mm's below top mark. So far, 93K on the odo, it's never budged. Knock on wood...
    jerrymildred and pghyndman like this.
  6. ETP
    2,803
    1,170
    Auburdale FL
    Wish everything had an Aircraft oil quantity gage.
    vvillovv likes this.
  7. bisco
    52,335
    yeah
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Always check the oil first thing in the morning before starting the car the oil dipstick tube will be dry and the level on the stick will be easier to read.
    If you pull over to a gas station and shut the car off and check the oil it will show quite low on the stick. Lots of oil in the upper engine and VVT oil circuit and cam actuator.
  9. vvillovv
    4,324
    1,512
    NY
    And apple plane play, so pilots have something to complain about too!
