Found a Hole - Is my Engine or Tranny Kaput?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by QuarterMileAAT, Feb 5, 2022.
  1. QuarterMileAAT
    77
    33
    NorCal
    Finallly getting around to do the head gasket repair thanks to warmer weather. Went to remove the splash panel and find a hole near what I believe is the bell housing(?). There is significant coolant in that area. There is some coolant in areas just a little higher up in the engine compartment. But I don't see where it can be running down from much higher up in the engine compartment.
    Did I develop a crack in my engine and is it caput? Or worse, is the a transmission side crack?
    Here is a zoomed in shot of the hole.
  2. PriusCamper
    PriusCamper Senior Member
    12,685
    5,120
    Pacific Northwest, USA
    Any signs of damage anywhere else? That's a very odd shape for a hole created from impact or failure... What happens when you stick something in there, does it keep going up or stops? Also how are your coolant and transmission fluid levels currently?
  3. ChapmanF
    18,071
    That looks more like a weep hole provided on purpose, though I have not just now rushed out to lie in the snow and compare mine.
    Is your coolant noticeably low in either the engine system or the inverter/tranny system?
    A cracked engine block could conceivably leak coolant into that area, and the tranny has a flat, O-ringed, sheet metal donut in the same area, directing coolant around MG1 (seen in some Weber U videos), which I guess could also be a source of a leak.
    But I think if my reservoir levels were not of concern, I'd probably just wipe the pink off and make a note to kind of watch it.
    PriusGuy32 likes this.
  4. QuarterMileAAT
    77
    33
    NorCal
    Sticking a small screw driver in there keeps going quite deep before it touches something. Drained the coolant and a significant amount came out, but the tank was almost empty. Didn't check tranny fluid levels.
    My reservoir was empty. Still, a significant amount of coolant drained out from the petcock. Inverter levels are good. I can't see damage, but of course it is hard to inspect. Hoping the coolant leak is from a hose at best. From the blown HG at worst. I am just wondering if I should go forward with the HG repair. Makes no sense to do so if the engine/tranny is kaput.
    Can anyone confirm if that hole is manufactured in?
  5. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    I just googled "Gen 3 Prius transmission fluid change" to be able to get pictures from someone else changing their transmission fluid just to see that area; that divit/drain hole? is in fact there on other Gen 3 Priuses. That is not a chip or crack, it is designed to be there.
    PriusCamper and jzchen like this.
  6. QuarterMileAAT
    77
    33
    NorCal
    Thanks @PriusGuy32 . I'll proceed then. There is significant fluid leak. Hope it isn't a cracked engine.
  7. PriusCamper
    12,685
    5,120
    Put more coolant in and send us pics or video of where it's coming out...
  8. QuarterMileAAT
    77
    33
    NorCal
    I am too far into the disassembly now to pour in more coolant. I'll just keep an eye out for where the leakage could have occurred as I go. I suspect it is from the HG as I can't see any coolant hoses going in through the back of the engine. I guess I should say, I am hoping. It could very well be a crack in the lower engine.
    Anyhooo, this thread is a wrap as we know that hole is manufactured in now. My progress will follow through on this thread.
  9. Mendel Leisk
    41,316
    I know what that little divot is:
    @Ragingfit noticed, and employed it, when separating his engine from transaxle. He speculated it was for just that purpose, and used it with a narrow cold-chisel: a few taps to brake the bond. it's noted in one of his videos on the 4th gen engine swap, pinned at top of Prius v modifications forum (technically appropriate location, but hard to find).
    Bottom line: it was like that from the factory.
    PriusCamper and Ragingfit like this.
  10. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
  11. PriusCamper
    12,685
    5,120
    Lol, although we do tend to continue chatting after the thread is wrapped up...
    jerrymildred and QuarterMileAAT like this.
  12. QuarterMileAAT
    77
    33
    NorCal
    All good. Seeing it in person however, it isn't quite regular. But then again, there was enough regularity to make you think it couldn't randomly chip off in such a shape. Also, there was a ton of coolant around it in my situation. So I thought I'd ask the pro's.
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    This sure is similar to the other recent thread where the guy is concerned about a trans leak. His photos show the same tell tale drain/weep hole. He was trying to figure out if it was oil/transfluid or coolant.
