Key fob low battery warning after installing new battery
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Zipy, Feb 6, 2022.
  1. Zipy
    Zipy Junior Member
    25
    Independence, MO
    2016 Prius. Had low battery warning. Replaced battery and still had the warning. Tried the spare fob and same thing even with a new battery in it too. I even tested the batteries and had 3+ volts in both of them. I can’t believe that both fobs would have gone bad, especially since the spare fob has never even been used. Something in the receiver gone bad? Anyone ever encountered this? Of course it’s out of warranty and I imagine mega $$$$ to fix.
    52,063
    check the 12v health
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,249
    847
    Monument, Colorado USA
    Do you store the key fobs near the vehicle or inside the vehicle? They have little radios and will activate if they sense a vehicle nearby and will drain the battery pretty quick. (Look at your key fob when walking through a parking lot...when you walk by another Toyota a little red light will blink!)
    I change out our fob and garage remote batteries yearly...else they seem to go out in the middle of winter at the worst time possible!
  4. Zipy
    Zipy Junior Member
    25
    Independence, MO
    12 volt is good. Installed a new one about a year ago. As far as where I store the fob, pretty much the opposite end of the house from the car.
  5. bisco
    52,063
    can't be the 12v then, they never go bad that fast, or lose voltage for any reason.
    try disconnecting the neg for a minute to reset everything
    ColoradoBoo likes this.
  6. Purrius
    Purrius Member
    155
    43
    Northeastern US
    I keep all of my fobs in a Faraday cage at home. (In this case that translates to an empty pokémon card tin.:LOL:) A cheap and handy solution for mitigating battery drain.
  7. BiomedO1
    3,766
    1,958
    SacTown, Ca
    I do the same, When I pull my keys out of my pocket - it goes into a Faraday bag. This also prevent thieves from using a signal booster to access and try to steal the car.
    I've been getting an intermittent FOB battery low message on my dash for the last month. Just got around to replacing the battery today. I'll see if that stops the intermittent message. First FOB battery replacement in 4 years.
  8. Purrius
    Purrius Member
    155
    43
    Northeastern US
    Definitely. I actually started doing it back in Oregon, back then it wasn't kind of sort of maybe technically illegal to steal a car. (Just remember to bring your Crime Committing Kit!)
    What brought me to this topic today was trying to get an answer for my friend. He owns a 2020 and asked me
    "Did you encounter such behavior of Prius FOB when it constantly shows "low battery, replace" even few days after replacement. And the FOB keeps working for months despite of this warning. It started doing that about 1.5 year ago."
    I suggested the Faraday cage and we'll see how that goes.
    I also saw people in Subaru forums mentioning perhaps fobs can get "stuck" in Battery Saving Mode when the battery is changed. I'm curious about this hypothesis.
    (How to Program a Toyota Key Fob)
    How to Program a Toyota Key Fob | Keith Pierson Toyota
  9. Buggs1a
    Buggs1a Junior Member
    112
    I have this issue. 2020 Prius. Had it for 2 months or so. Car tells me replace the battery. I did. It’s worse now. It won’t work sometimes. Car still says replace battery. I have to push lock button first many times to get the car to work sometimes. Then push unlock button to unlock doors or lock them.
    Yesterday I went to go somewhere. Didn’t work. Door not unlock. After a minute or so of pushing lock and unlock on the key the car finally opened. When where I was going. Hrs later go back to car to come home. Door unlocked. Then car says no key detected. Couldn’t start the car for awhile. Finally worked.
    Looked on google for answer. Says if car still says replace battery then reprogram key. To re program it says use the key to put into ignition slot twice. Then do other stuff with the doors. There is no ignition slot so I’m confused.
    I can’t go anywhere till this is fixed. Not comfortable.
  10. Zipy
    Zipy Junior Member
    25
    Independence, MO
    I should have updated long ago. Anyway, turns out the “cheap “ batteries are crap! Even though they test at 3+ volts they just do not work in my remote. Went to the dealer, he immediately put a name brand battery in it and of course it worked perfectly. Advice- Do NOT buy the cheap China batteries!
    Purrius and Brian1954 like this.
  11. BiomedO1
    3,766
    1,958
    SacTown, Ca
    They may have adequate voltage, but how do they load-test. I thought the new batteries should be closer to 3.1-3.2VDC - but I have a calibrated Fluke meter. My job requires annual calibration certificates for my test equipment.
    YMMV
  12. Brian1954
    Brian1954 Senior Member
    2,299
    914
    South Central PA, USA
    New 3v batteries should be 3.3v. I have problems with the fob when the battery drops down to 3.0v, and then I replace it with a new battery. I always use a meter to check the voltage of the new battery before I install it in the fob.
    BiomedO1 likes this.
  13. Buggs1a
    112
    Anything on my post?
  14. bisco
    52,063
    get a free 12v load test at many auto parts stores
  15. Brian1954
    2,299
    914
    Did you check the voltage of the battery in the fob or replace the 3v fob battery?
  16. Buggs1a
    112
    Ya I posted above. I have a bunch of batteries new. I put a new one in. Car still says to replace. And articles say to reprogram key. But they says to put the key in the ignition slot. There is no slot. So whuuuut.
  17. Brian1954
    2,299
    914
    Just because you have a bunch of new batteries doesn't mean that the batteries are any good. Use a meter to measure the voltage of the new batteries. Do they measure 3.3v? If not, you need to buy better new name brand batteries. See posts #10 & #12.
    The Google search that you did gave you information about a Gen 2 Prius, which is not applicable for your Gen 4 Prius.
  18. Zipy
    Zipy Junior Member
    25
    Independence, MO
    As I recall my new China batteries all showed 3.3 volts, but they sure didn’t properly power the remote. Name brand battery installed and all was well with the world.
    Brian1954 likes this.
  19. bisco
    52,063
    it's difficult to load test button batteries, but that's what they need to be sure they are working properly
  20. bisco
    52,063
    make sure you have the battery right side up?
    did they give you the second fob with your purchase?
