Best headlight bulb
Discussion in 'Gen 3 Prius Accessories and Modifications' started by nicoj36, Nov 26, 2016.
  1. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Sure, but HID bulbs need a very expensive ballast.
  2. CivicSky
    CivicSky Member
    163
    71
    San Deigo
    I tried 3 different brands:
    1) DDM 30W 5000K HID with battery rely harness. Lifetime warrenty and used for 8 years without problem.
    2) SL1 H11 LED 5000K bulbs by Diode Dynamics. Good quality & have transplanted to my wife's car ($150 pair and have been using for 2+ years)
    3) Lasfit D4S LED 5000K. ($80 pair during last Christmas sales) Good color and bright.
  3. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sorry for the long post. It got away from me. Lol
    I don't know if I'd recommend them purely because of their high cost, but I've been happy with my GTR Lighting Ultra 2.0 LED bulbs from Headlight Revolution. Extremely bright, good color to my eye(6000K - cool but not blue), and a very good beam pattern. But at almost $500 for the 4 bulbs you would need, I would recommend thinking twice about buying them, then three times, then about ten times more.
    Here's the thing about LEDs: Not all are created equal by any means. Like most all modern vehicles, Priuses use reflector and/or projector lenses in their headlight assemblies. (My 2010 uses reflectors for the low beams and projectors for high.) These assemblies are built for the light source to come from a very specific point. No LED bulb can do this perfectly, but some are much better than others. If the light is emitted from the wrong point, the beam pattern will be all messed up. This is when oncoming drivers get blinded and/or the new LED bulbs appear dimmer than the halogen bulbs they replaced.
    Something else to note: There is no such thing as a road legal LED bulb that goes into a halogen socket. Even the stupidly expensive bulbs I have are technically not road legal.
    Two other things to consider with LED bulbs are the quality of the diodes and the size and quality of the heat dissipation. There are a handful of quality diode manufacturers and a ton of cheap copies. Cheap diodes will have inconsistent color, inconsistent output, and inconsistent life. Poor heat dissipation will cause even quality diodes to fail long before they should. Most of the good high output LED headlight bulbs have aluminum heatsinks and fans to dissipate the heat. (BTW, color temperature has absolutely nothing to do with heat failures. That comment gave me a laugh.)
    If you decide to get either LED bulbs or go for an HID kit, one of the first tests you should do after install is to put your car in front of a flat wall, preferably a white or light colored one. A white garage door works great for this. Turn on the low beams. There should be a distinct cutoff of the light a little higher than the top of the headlight. How much depends on the distance from the wall and the angle of the car, so just look for a clean horizontal cutoff. Very bright below the cutoff, almost nothing above. Within the lit area, there should be two stronger areas straight ahead of the car, but there shouldn't be a huge difference between the bright areas and the not quite so bright areas. There should be more light to the right of the car than to the left.
    On high beam, there should still be a sharp cutoff, but it will be somewhat higher than the low beam cutoff. There will also be quite a bit more light cast to the sides, especially on the right(to help illuminate the ditch). If you install very high intensity bulbs, I also think you have the responsibility to have your headlights professionally aimed so as not to blind other drivers.
    If you install new bulbs and you have massive hot or dark areas all over the place, you've got crap bulbs. If the beam goes noticeably above the cutoff in parts, you've got crap bulbs. (Or you've installed them incorrectly and the light isn't coming from the right spot.)
    While I think they way overcharge for their stuff, Headlight Revolution does have some good videos showing quality bulbs(their own, of course lol) and cheap Amazon bulbs that are terrible, and what happens when you put those bulbs in factory headlight assemblies.
    tldr: If you buy cheap bulbs on Amazon you're more than likely going to get crap.
    Pixel 4a ?
  4. doctorman
    doctorman Member
    210
    36
    NY 11020
    anyone tried any new models of LED of HID light in 3rd gen prius low beam with projector housing?
    2012 prius v looking for around 5000K color bright low beams without breaking the bank but yet something that will last given how hard it is to get to the bulb in these cars
  5. doctorman
    doctorman Member
    210
    36
    NY 11020
    any update on your innovited HID?
  6. doctorman
    doctorman Member
    210
    36
    NY 11020
    how are the Lasfit surviving? any update?
  7. rjparker
    10,436
    6,544
    I bought Lasfit h11 a year ago and they are fine. The brightness and beam pattern are good.
    LEDs run hot and need built in fans. They also have a power supply which can create interference so you want “can bus ready” or similar even though gen3s don’t control their lights directly with can bus.
    #27 rjparker, May 7, 2024
    doctorman likes this.
  8. doctorman
    doctorman Member
    210
    36
    NY 11020
    thanks
    ordered GTR Ultra 2 H11 LED
    will see how that goes without canbus
  9. rjparker
    10,436
    6,544
    $116 for one bulb is pricey on Amazon
  10. doctorman
    doctorman Member
    210
    36
    NY 11020
    got them for 100$ for a pair from a friend
    otherwise yeah 200$ is the price of any good LED or HID for pair
  11. PriusHead05
    PriusHead05 Member
    318
    When you get them installed, please update us with a picture of the beam pattern and brightness.
  12. doctorman
    doctorman Member
    210
    36
    NY 11020
    The GTR Ultra
    The GTR Ultra 2 are day and night compared to the original hallogen
    the light is spread so nicely ,
    the cut off line is sharp.
    it is 3 times brighter
    and with lifetime warranty hopefully it was a well worth it investment
    the installation took 15 min for both , plug and play, no need to adjust the light level after.
    that was for low beam. fo high beam any cheap LED would worksince it is not used all the time so it wont get hot and burn.
    also changed the corner light in the headlight it is a regular T10,
  13. CivicSky
    CivicSky Member
    163
    71
    San Deigo
    Yes, the Lasfit pair are still nice and bright! I also use their headlight products on 4 other vehicles and they are all functional!
  14. txtabby
    txtabby 2011 Prius 4
    139
    Austin, TX
    Really..? Very interesting. I switched all bulbs over to LED a few yrs ago and was happy, now the headlight assembly is foggy enough that I need to change it out for new-have the left/right parts. But one Hi-Beam burned out & was going to change everything. Ordered a set on Amazon, the plug won’t work. But after reading this, sounds like it’ll be Much easier just to go back to OEM. Thanks!
  15. rjparker
    10,436
    6,544
    Repair Geek youtube channel recently reviewed current LEDs vs Halogens. Most of the LEDs were dimmer than halogen at 265ft running low beam with a couple of notable exceptions from Auxbeam.
    IMG_0284.jpeg In this chart from the video, the Low and High beam Lux strengths are compared.
    katzi likes this.
  16. Brian1954
    Brian1954 Senior Member
    2,385
    958
    South Central PA, USA
    The post you quoted was written over 9 years ago. Things change over that length of time. It is not surprising that there are more options available today than there were 9 years ago for headlight bulbs.
