where is the EGR in the prius sold in Brazil?
Discussion in 'Gen 3 Prius Main Forum' started by heltonsc, Mar 15, 2021.
  1. heltonsc
    heltonsc Junior Member
    42
    brazil
    Oi! Tenho um prius 2013 e sempre leio sobre a limpeza da válvula EGR e os problemas da junta na cabeça.
    Apesar de termos pouquíssimos prius gen 3 no Brasil, nunca vi esses problemas aqui.
    Fui procurar a válvula EGR para fazer a limpeza como visto aqui, mas não a encontrei.
    Onde está o EGR?
    Fotos do meu prius:
  2. ETC(SS)
    7,134
    Os carros brasileiros usam etanol e, portanto, provavelmente não precisam de válvula de recirculação de gases de escapamento.
    (Brazillian cars use 100 %ethanol, and so they probably do not need an exhaust gas recirculation system such as that used by nasty old American gasoline burners.....)
    heltonsc likes this.
  3. heltonsc
    42
    brazil
    I always heard that the prius sold here in Brazil was the same as in Europe or Canada, do they also not have EGR?
    The gasoline fuel sold here is really poor quality and contains 27% anhydrous ethanol
  4. ETC(SS)
    7,134
    ^ What I enjoyed during my last visit to Recife.....
    VERY fond memories of Brazil!!
  5. ASRDogman
    ASRDogman Senior Member
    7,542
    3,895
    They also don't have the power or can go as far on a gallon of that stuff. :)
  6. ETC(SS)
    7,134
    Oh?
    I thought that the last time I was there Brazil used a higher concentration of Ethanol - as high as 100%
    It might be the very fact that Brazilian fuels differ widely in your 26 states, as opposed to our 50 states which (for better or worse) have more or less the same gasoline quality.
    Our gasoline is mostly a10% ethanol blend with some states offering 0% ethanol and others that use 85% ethanol...but the fuel itself is of about the same QUALITY.
    Our federal regulations are....for better or worse....probably much more tightly enforced.
  7. heltonsc
    42
    brazil
    consumption within the city or on roads is 20 km / l (47 mpg) without AC.
  8. heltonsc
    42
    brazil
    here are only two car fuels here:
    Petrol (E27)
    Ethanol (100%)
    ethanol is used in Flex fuel cars.
    Curiosity, the prius works with 100% ethanol, just turn on the ECU light, but everything goes smoothly.
    the current cost of ethanol is very high, gasoline has been the preference.
  9. heltonsc
    42
    brazil
  10. Paladain55
    Paladain55 Active Member
    404
    164
    The South
    Anybody have the photos in this thread?
  11. Mendel Leisk
    41,332
    OP's image postings were likely links, not directly uploaded to Priuschat. And they've gone.
  12. luis perez
    luis perez Junior Member
    49
    17
    Quick comment: If you right click the the link becomes available and the pictures are there: No EGR system....
  13. johnHRP
    johnHRP Active Member
    643
    185
    KA, DE
    Excel
    Most Brazilian do not use Ethanol these days. It is more expensive to run, damaging engine faster, and polute as much as gasoline with a lot of toxic acetaldehyde. On the other hands, Sugar cane Farms use a lot of fertilizer that required a lot of fosil fuel to produce. At the end the net is often more poluting than just straight using gasoline.
    The EGR and catalytic converter are often missing in developing countries including Thailand, Indonesia, Malaysia, Brazil, etc. For instance, Toyota Hilux Champ, a pickup truck with 2GD 2.4 Diesel or 2.0L Gasoline, it can take high sulphure diesel and 85 octane gasoline. It does not have EGR nor catalytic converter and sell it $10-20k each for a pickup truck as big as Tacoma/Hilux base. It is very basic, everything is manual, no insulation. Just basic airbag.
