2010 Prius won't start - all lights on check hybrid message
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by saddy.dj, May 14, 2022.
  1. saddy.dj
    saddy.dj New Member
    US
    2010 Prius won't start - all lights on and check hybrid message. Happen suddenly first time ( no warning sign before) .
    While drive few miles suddenly all the lights on dashboard blinked along with check hybrid system message , while still running, starting loosing power as gas won't work power staring gone somehow realized and came to safe stop. Had to tow back card home.
    - Check 12 volt battery , AutoZone guy said it looks great. Was able to run a/c fan and head lights.
    - After putting back 12v all light were on but without check hybrid message, tried to start didn't work.
    - In second attempt with long press power button gas engine started but as soon I release button it stopped.
    - In third attempt same thing happen, this time check hybrid message came again.
    135k + miles , original hybrid battery.
    Awaiting OBD2 device delivery to check any error code will post. Kind of worried of fraud repairs, can't pay more money.
    52,400
    which device did you order? they don't all work with prius.
    it is worth measuring the voltage at the jump point under the hood with car off.
    did you run out of gas?
    might be a blown fuse, possibly inverter pump
  3. saddy.dj
    saddy.dj New Member
    US
    Any suggestion what this hose called ? Its fall off and was causing P3190 error code ( without any other codes)
      File size:
      461.1 KB
      File size:
      672.4 KB
      File size:
      501 KB
