2011 IM+EGR Coolant Cleanup Saga - With updated details
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, May 16, 2022.
  1. ChapmanF
    18,556
    Well, so you don't have to give up; we know what the best available proxy is, and it's what the built-in monitor test already uses, so you call up the test result, and there you are.
    Unless you're driving a Japanese Prius, where apparently Mode 6 test results aren't available. That would be a disappointment.
  2. Merv Himself
    Merv Himself Junior Member
    71
    Georgia, Florida
    2013 Prius v wagon
    Sorry I'm late replying to this. Anyway, based on what I saw, it's those little metal tabs that connect the screen to the gasket. That's what gets in the way of it seating properly.
  3. ChapmanF
    18,556
    So I'm kind of wondering if the updated manifold has extra notches where those tabs go, so it can seat properly.
  4. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    That's an excellent question. Alternatively, maybe the gasket is sort of a multipurpose thing they put in different kits for various makes & models.
  5. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    I hate to be the bearer of bad news, but from the color of your engine coolant tank I'd bet money you already have a blown head gasket. It should look nice and pink like the inverter coolant bottle to the right, but it will quickly turn that nasty brown color when contaminated with combustion gases.
    CR94 likes this.
