Found this carpet under the hood
Discussion in 'Newbie Forum' started by Alex80, Jun 20, 2022.
Tags:
  1. Alex80
    Alex80 New Member
    225 E 138th bronx
    Hi there,
    I found this thing in my hood today and I'm baffled. What is it? How it got there? Any ideas? Thanks! IMG_1798.jpg
  2. Tideland Prius
    16,589
    That looks similar to some of the insulation used around the car.
    Alternatively, the previous owner was trying to keep the engine warm by using insulation (and thus improve MPG). But of course they would've used a Scangauge to monitor engine temperature to ensure it doesn't overheat.
  3. Alex80
    Alex80 New Member
    225 E 138th bronx
    Hi thanks for your reply. I had this Prius for a while but I'm still noob somehow :)
    My only explanation is that rat drag it in to make the nest.
    Also isn't this insulation flammable to be near the engine?
    Thanks
  4. Tideland Prius
    16,589
    The rat theory is also a possibility though it seems too neat for that.
    Depends on the material and what it's physically touching but yes, it could be a fire hazard.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,495
    2,468
    Taylors, SC
    It's apparent that it's the underhood heat and sound insulation dragged off the retainig clips and down onto the engine. Post a photo of the area under the hood.
  6. Mendel Leisk
    41,791
    How long have you had the car, and how often do you pop the hood?
    We had a rat take up lodging in our engine bay, dragged a small, plush toy, housecoat sash and sundry in there. Still, you're pic looks more like humans at work.
    BTW: your address is maybe too specific? Unless it's bogus, lol.
  7. fuzzy1
    10,571
    It doesn't look anything like the insulation still attached to the underside of my hood.
  8. kenmce
    kenmce High Voltage Member
    1,549
    522
    NY
    He's from the Bronx. Doxxing holds no fears, nor does COVID, nor pizza rats, nor much anything else, save not having the cover fee for his favorite watering hole.
  9. OptimusPriustus
    OptimusPriustus Active Member
    335
    142
    Finland
    Previous owner may have experimented with additional insulation in the hood. And now it came off.
