Front Defroster/Defogger, whatever you want to call it
Discussion in 'Gen 3 Prius Technical Discussion' started by nivekonbass, Jun 20, 2022.
  1. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    Hi guys,
    Hoping to get some help with a problem I'm having on my Prius. When I try using the windshield defroster/defogger it just doesn't do anything. When I hit the button, no light or anything. Rear one works, but windshield does not. Heat/AC works fine, just this button doesn't do anything.
    Where can I find the fuse box for this (no manual in my car, online manual doesn't show the windshield defroster location from what I'm seeing)?
    Is there anything else I should check out? Never had this problem before, please forgive my ignorance as I got this car 2 days ago.
  2. ChapmanF
    18,400
    I doubt you're going to find any 'fuse' that will be the cause of your defrost button having no effect. That's just one of the buttons built into the HVAC buttons-and-display unit, and if the display and other buttons work, it's getting power.
    From your description, my suspicion would land first and hardest on the button itself. A relatively unadventurous person might just get that panel (maybe a working used one, or one borrowed from another Gen 3) and see what happens. It only takes a minute to pop that panel out. If it were mine, I would probably see if I could get to the button contacts for cleaning.
  3. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    Why do you think it's the button itself?
    This is a 13 Prius with 80k miles. is it likely that this button would be dirty enough to warrant a new climate panel? Is there a relay or something I can test for this before I go spending money on a new climate panel? I do not have access to another gen 3 prius
  4. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    you called it. it is the button :p, sorry for questioning you <3
  5. ChapmanF
    18,400
