Help please part dos: HV Battery Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DigDoug, Jun 22, 2022.
  1. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    If you do get another battery, Green Bean is decently priced around 1600 and for another 50 you can get a lifetime warranty, and there's a chance they can have someone come to your car and do the work in time for your trip Sunday.
    DigDoug likes this.
  2. DigDoug
    DigDoug Junior Member
    64
    17
    Pennsylvania
    Green Bean? What is that?
  3. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
  4. DigDoug
    64
    17
    Pennsylvania
    Hmm I will have to check them out, do you know what the failure rate is for them?
  5. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    not sure but I've had mine for 14 months so far without any issues. and for 50 bucks for a lifetime warranty there's really no risk.
  6. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    We could use some data (Dr Prius, Torque, etc) - yes, a cell in a block could be going bad. Or there could be a connection problem. Or there could be a voltage sense wire / connection / ecu pin problem.
  8. DigDoug
    64
    17
    Pennsylvania
    Trying to upload my screenshots
  9. mr_guy_mann
    4,036
    1,965
    NJ-USA
    I was referring to HV battery voltage data. Particularly the freeze frame data for the P2023. Also some captures of live HV battery block voltages while driving the car hard (accel and decel).
    We want to see what values are that the ecu doesn't like. If block 13 is 1.0-1.5V lower than the others while discharging, that usually points to a failed cell in one of the sealed battery modules in that block.
  10. DigDoug
    64
    17
    Pennsylvania
    To be honest the four miles I drove it was the last time the car has been driven. I don't think I have the ability to capture the measurements you are speaking of with Blue Driver.
  11. mr_guy_mann
    4,036
    1,965
    NJ-USA
    Well, if blue driver can't do it, you can look at the app review sticky thread at the top of the Technical discussion thread.
  12. DigDoug
    64
    17
    Pennsylvania
    Green Bean rectified the problem for me on Sunday, less than a half an hour and my Prius was back to “new”. I want to thank you all for your help. Mr-guy-Mann I looked at the thread you recommended and I found some interesting information there. I will have to try to narrow down a new reader.
  13. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    I’m assuming they kept your NPB modules? did they ask about the cylindrical cells or give you any issues?
  14. DigDoug
    64
    17
    Pennsylvania
    I have heard nothing from them as of right now. I will update if they do contact me.
  15. alftoy
    1,132
    517
  16. DigDoug
    64
    17
    Pennsylvania
    Not that I know of
    donbright likes this.
