Battery question from an old lady
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by BettySue, Aug 21, 2022.
  1. BettySue
    BettySue Junior Member
    17
    Ohio
    2014 Prius c
    I
    I have a 2014 Prius C. I like the car very much. Her name is Betty.
    However, I run into issues because I don't drive often. As a result in the winter I end up with a dead battery. I know it is because I don't drive enough. I read about getting a trickle charger and that would be nice. However, the electric outlet outside is as far as possible away from the carport. I would have to have an extension cord that is more than 100 feet long to reach it.
    Then I read about putting the car in "Ready Mode" and letting it run for an hour about once a week. I am posting a picture of what I read for you.
    I am thrilled about that option, at least for in winter. I told my daughter and son-in-law that I had already done that a few times. They were really upset with me and they talked to a mechanic at the Toyota dealership and he said I could ruin the battery doing that.
    When I read that article on here, it had said that the Prius battery was made just so you could do that, but of course I didn't copy that part off and I don't have the link. I have hunted for the link for several days.
    Could someone here please talk to me about this? Is this information correct and does it harm the car?
    Thank you,
    Susan
  2. BettySue
    17
    Ohio
    2014 Prius c
    I
    I see that my picture did not post, so here is what it said:
    "Prius Battery
    To maintain optimal battery performance, the batteries must be used.
    This can be done by driving the vehicle, but there is also a maintenance process you can follow. This consists simply of putting the car in "ready" mode for about 60 minutes once per week. Toyota highlighted this process in a recent post.
    To maintain proper charge, simply go through the normal start procedure. Press the "start" button with your foot on the brake and ensure that the "ready" light is illuminated on the dashboard.
    There's no need to keep your foot on the brake after the "ready" light comes on, but you need to ensure your vehicle's transmission is in "park" and the parking brake is engaged.
    Toyota and DC Battery Hub both recommend keeping the car in "ready" mode for about 60 minutes before switching it off again. During this time, you may feel the internal combustion engine kick in...this is a normal part of the self-charging process."
    2010moneypit? likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,839
    5,203
    Pacific Northwest, USA
    You son-in-law, daughter and Toyota Stealership are wrong about harming your battery. Prius are used in that way by lots of people. However it's not a very effective way to charge the 12v. You need to get yourself a legitimate battery charger like this one: https://www.ebay.com/itm/354203591176 And periodically park your car close to an outlet so you can charge it!
  4. PriusII&C
    PriusII&C Active Member
    426
    144
    San Jose, California
    Another way to extend your battery's idle time is to install a battery switch. Turn the switch to "off" position when you plan to park your car for a few days. However, you will lose your radio stations this way.
  5. PriusCamper
    12,839
    5,203
    Some Prius C actually come with these switches near the underside of the right back seat.
  6. ChapmanF
    18,300
    When I had an old vehicle sitting in my driveway waiting to be sold, I was able to keep the battery very nicely maintained with a solar battery maintainer. I just set the panel on the windshield with the wire under the wiper to hold it in place. A maintainer with a five-watt panel did the trick easily.
    nicoj36 likes this.
  7. bisco
    52,067
    letting the car sit in ready is absolutely not a problem.
    many here have been doing it for days at a time to sleep inside.
    another option is a good 100' extension cord:
    ref=asc_df_B00004SQF4
  8. BettySue
    17
    Ohio
    2014 Prius c
    I
    PriusCamper, PriusII&C and ChapmanF thank you so much! I like the sound of that battery switch and the solar battery maintainer. Finding an outlet to use the other battery charger is not going to happen. The only way I could find one closer is to let my front door open and then run an extension cord from the living room.
    I am also thankful to know that I will not damage the car to put it in "Ready" mode to let it run an hour. That is a relief.
  9. BettySue
    17
    Ohio
    2014 Prius c
    I
    Bisco, I actually have that exact extension cord. I bought it from that link November 1, 2020. I paid $38.48 for it.
    #9 BettySue, Aug 22, 2022
  10. Mendel Leisk
    41,625
    Maybe get that 100’ cord and a smart charger. CTEK 4.3 is working well for mine; pretty much constantly connected. They come with a quick connect, so you can avoid dealing with alligator clips.
    Video #23 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    shows where to connect positive lead. It would take a mechanic maybe an hour if you got it done.
  11. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    What about the hybrid battery sitting for long periods of time. The battery likes to be exercised (driven) it’s not good for these cars to sit for long periods of time.
  12. Mendel Leisk
    41,625
    Owners manual (if like gen 3) says at least every 3 months, for hybrid battery exercise. As long as car is driven sporadically should be good. Especially is you do long drive every so often.
  13. BettySue
    17
    Ohio
    2014 Prius c
    I
    Mendel Leisk, is this the correct charger? I am in northern Ohio. I actually think I am unlikely to do this, but I appreciate the option and I am saving everything I am learning here. I am very happy there is more than one option.
    My issue is that I drive very little. I drive to the mailbox once a day and cover 1/4 mile. Other than that, I only drive to doctor appointments every 3 months and to vet appointments every 8 weeks. I put about 500 miles on the car last year. I need to drive more.
    Now it won't let me post my link.
  14. Mendel Leisk
    41,625
    It looks like CTEK has juggled the names; this is sim to what I’m using. Maybe search for “ctek mxs 5.0”:
    CTEK - 40-206 MXS 5.0 Fully Automatic 4.3 amp Battery Charger and Maintainer 12V
    Doug McC likes this.
  15. BettySue
    17
    Ohio
    2014 Prius c
    I
    Thank you so much! I just found it on Amazon.
  16. ChapmanF
    18,300
    Just putting the car in READY, as she would be doing to charge up the 12 volt battery anyway, will bring the traction battery up to a decent state of charge as the very first thing before the engine cycles off.
    That's all the traction battery needs. It gains no further benefit from Italian tune ups.
  17. ColoradoBoo
    ColoradoBoo Senior Member
    1,250
    847
    Monument, Colorado USA
    Yes driving more would be the best thing for the 12-volt and traction batteries, the transmission, ICE engine, brakes, etc. Maybe pick out a park or scenic place that's a 20-30 minute drive and go there once a week or every other week? This would be much better than putting it in just maintenance mode for an hour (which wouldn't help the transmission and other parts that need to be moving around to avoid rust/corrosion.)
  18. BettySue
    17
    Ohio
    2014 Prius c
    I
    Thank you, ChapmanF. That is probably what I will do when the weather starts getting bad.
    ColoradoBoo, I just had an issue with rust on my rotors due to my lack of driving. I am going to try to drive more and like you said figure out a nice place to drive. The scenic place is across the road from where I live. LOL It is gorgeous there, but won't put miles on my car.
  19. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    Wouldn’t the battery switch completely disconnect the battery? From what I have been led to understand from this site, that wouldn’t be good for the car, right?
  20. Doug McC
    1,079
    418
    Midwest
    2022 Prius
    What area of Ohio are you in. If in the north in the snow belt I sympathize with you!
