ABS wiring diagram C1465
Discussion in 'Prius c Technical Discussion' started by gus1203, Aug 21, 2022.
  1. gus1203
    gus1203 Junior Member
    34
    Cicero, IL
    Hello,
    I have a 2012 Prius C base model.
    I replaced both front left and right abs sensors and still getting code C1465 for left sensor bad.
    would anyone happen to have a wiring diagram for the ABS system.
    I replaced the receptacle connector for the left side as it was broken. Wires and pins check ok. I need to trace back to the ecu.
  2. Sonic_TH
    Sonic_TH Active Member
    573
    96
    Puerto Rico
    2016 Prius c
    Does the brake pump runs constantly?
  3. gus1203
    34
    Cicero, IL
    no pump works fine.
    I’m going to jumper receptacle side and hope the wheel bearing is bad. Otherwise I have to trace back wiring to ecu.
