ABS wiring diagram C1465
Discussion in 'Prius c Technical Discussion' started by gus1203, Aug 21, 2022.
  1. gus1203
    gus1203 Junior Member
    23
    Cicero, IL
    Hello,
    I have a 2012 Prius C base model.
    I replaced both front left and right abs sensors and still getting code C1465 for left sensor bad.
    would anyone happen to have a wiring diagram for the ABS system.
    I replaced the receptacle connector for the left side as it was broken. Wires and pins check ok. I need to trace back to the ecu.
  2. Sonic_TH
    Sonic_TH Active Member
    525
    83
    Puerto Rico
    Does the brake pump runs constantly?
  3. gus1203
    23
    Cicero, IL
    no pump works fine.
    I’m going to jumper receptacle side and hope the wheel bearing is bad. Otherwise I have to trace back wiring to ecu.
