ABS Accumulator?
Discussion in 'Gen 2 Prius Technical Discussion' started by Gen2Prii, Nov 28, 2019.
  1. Gen2Prii
    Gen2Prii Junior Member
    24
    South Florida
    Where's a good source to get an abs actuator? Rockauto and dorman are out of stock. The used units on eBay seem like they wouldn't last long. Anyone know a source to get a decent part? The abs accumulator noise that is present when turning off the car, has changed from a buzz to a grinding noise. No triangle but I feel it coming soon
    abdelfattah yassine likes this.
  2. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    If you are only hearing the noise when you turn off the car (not while you are driving it), it may not be the braking system at all. Possibly it is the pump that fills the Coolant Heat Storage canister (aka "thermos") that is making noise, a much less serious problem.
  3. Gen2Prii
    24
    South Florida
    Ah ok, thanks, that would make sense. The check engine light has been on for 2 months with code 1121, a coolant control valve
    davecook89t likes this.
  4. abdelfattah yassine
    abdelfattah yassine New Member
    Anyone knows where to get an affordable brake booster and pump ? Code I have is c1391
  5. abdelfattah yassine
    Hi. Did you get what you're looking for? I'm in same situation.
    #5 abdelfattah yassine, Aug 21, 2022
  6. p200
    p200 New Member
    Baltimore Maryland
    I've been looking at factory parts for mine and all I'm finding is about $1100. My local dealer wants $1700 + $1000 to install. I'm getting the pump motor running about every 20 sections.
    This seems to be the going rate online from Toyota.
    2006-2009 Toyota Prius - Modulator Valve - Toyota (44500-47141)
    Would post a link but I'm new so not allowed yet.
  7. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    Yes, that's a good price (discounted from the RRP of around $1,750) for a factory new part.
  8. Ashley Johnson
    Ashley Johnson New Member
    Cartersville, GA
    I had my CHS changed to new one 3 times almost 2 years ago & the 3 times was from replacing it in check engine?had warranty kn oart) then I was told water pump to just drive until i could afford it but place closed down & no shoes for Prius around ms. Well, over time things added fo other ones & changed same part, thermostat & control valve after being informed that different results come. I was reading up & eit all dash sensor lights on รท& issue housing remake than it is thise osrts but have t
