Prius shuts off gives red triangle, hybrid warning light, main battery light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Laman012, Sep 11, 2022.
  1. Laman012
    Laman012 Junior Member
    I was driving my gen 2 prius this evening on the freeway when suddenly the gas pedal stopped doing anything. I pulled over as fast as I could while losing speed quickly. When I stopped, the car sputtered and died. Just had an oil change and regular service this past week.
    Red triangle came up, hybrid indicator came up, and the main battery indicator came up.
    Car still turns on and goes into ready mode, tries to charge the battery, but stays on one bar. The engine then sputters and kicks before turning off. Checked the 12v with the display check method. 12v when in ACC, 14.4v when in ready mode.
    250k miles on the car, hybrid battery was replaced in 2017 with a reconditioned one, which lasted way longer than it was supposed to.
    Is that all that needs to be done, replace the hybrid battery again? Or is there another issue?
    #1 Laman012, Sep 11, 2022
  2. ChapmanF
    18,289
    About how long would you say the engine spins, before it sputters and kicks and turns off?
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,056
    1,980
    NJ-USA
    Have you checked oil (and coolant) levels?
    There are lots of "could be's" here. Could be an inverter problem. Could be an engine problem (when was the last time you filled up the gas tank?) Could be a HV battery problem.
    If there are warning lights on, then there should be diagnostic trouble codes set in the ecu's that control those lights. You would need a capable scantool to read them (most scantools can't communicate with all the ecu's on a Prius).
  4. Laman012
    For about one minute.
    It tries to charge the battery, but it doesn't work, then it shuts down.
  5. Laman012
    Oil change and all coolant/fluid levels checked less than a week ago.
    Gas tank filled two days ago.
  6. Laman012
    12 volt battery shows 11.5 when tested now.
  7. ChapmanF
    18,289
    No check-engine light? Sure sounds like the kind of situation that would post a P3190.
  8. Laman012
    Oops, yes, check engine light on.
    No codes, will tow to local repair shop tomorrow.
  9. Laman012
    Just tried to turn it on again. Goes into ready, ICE tries to kick in, but makes a loud noise, sputters and dies.
  10. ChapmanF
    18,289
    Those various warning lights all indicate that there are trouble codes present, but different scan tools have very different abilities to retrieve all codes from a Prius; we have a thread that compares several of them.
    Ideally, the local shop will have a scan tool that is able to retrieve the codes.
  11. Laman012
    The mechanic replaced the air filter when he changed the oil.
  12. sydney2008
    sydney2008 Junior Member
    45
    Savannah
    I posted a similar - though not the same - issue today after getting an oil change and engine air filter replacement yesterday. My car had all the dash lights, but continued to operate normally. Initial reading at the service center is an issue with the inverter coolant pump. I’ll hopefully learn more tomorrow… watching this thread, good luck!
  13. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Have you checked the engine for oil?
