Considering Head gasket replacement - 2011 Prius - 215k miles - P0303 misfire
Discussion in 'Gen 3 Prius Technical Discussion' started by An2TheTwan, Jul 18, 2022.
  1. An2TheTwan
    An2TheTwan Junior Member
    97
    New York
    in the gasket master video, they clearly are in a piece that is an extension of the short block. I checked the oil filter housing and didnt recall seeing anything there either.
  2. rjparker
    9,908
    6,112
    Oil Filter bracket and orings
    #82 rjparker, Oct 13, 2022
  3. An2TheTwan
    97
    New York
    do these rings sit on the block and i will have to glue them or something? Because in the picture I posted there clearly is no grooves for the rings to be inserted into.
    Are the rings/grooves on on timing chain cover?
  4. ASRDogman
    ASRDogman Senior Member
    7,460
    3,876
    When you put the timing cover on, you will see the grooves on the timing cover.
    Which is what I meant, but said on the housing. I guess I was thrown off by the picture
    with the timing cover off.... sorry...
    Look on the timing cover... like in the photo above.
    An2TheTwan likes this.
  5. Mr. F
    Mr. F Active Member
    387
    255
    Washington
    For clarity, this is where the o-rings go:
  6. An2TheTwan
    97
    New York
    okay, thank you. It looks like they go onto the timing chain cover. I couldnt check cause I live about an hour from where my Prius is currently at lol
    I have a couple more questions with other O-rings, will post tomorrow
  7. Mendel Leisk
    41,029
    I replaced the oil filter assembly on our 2010 (converting to spin-on style oil filter): it goes on top of the timing chain cover, which has oil passage holes with recesses for those O-rings.
    Spin on oil filter | Page 2 | PriusChat
    Ah, see @Mr. F has addressed it, anyway.
    #87 Mendel Leisk, Oct 14, 2022
  8. Tombukt2
    12,725
    2,273
    Just put a dab of grease to hold o ring in place. sealer if you work slower.
  9. An2TheTwan
    97
    New York
    My next question:
    I went to a Toyota dealership and asked for assistance finding these O-rings. Although the representative I worked with was pleasant, I felt he was unsure about the parts I needed.
    The next o-ring in question is under the valve cover. The new one I ordered (right) is smaller than the original (left). Is it common for these to swell up/increase in size over time? This looks pretty significant size difference.
    Link to video 32:43 seconds
    (also, the other o-ring I ordered which looks like a ghost/surprise face/has 3 circle - this was roughly the same size as the original.
  10. Mendel Leisk
    41,029
    Not 100% sure, but from the so-so pic on this page:
    CYLINDER HEAD. 2011 Toyota Prius Hatchback | Toyota
    Second pic on that page, you need to select it, and enlarge it. Screen-grab:
    It might be:
    90430-10024
    FWIW, Toyota makes a gasket kit, includes head gasket and all these. Part number for the kit is:
    04111-37315
    found in attached.
    #90 Mendel Leisk, Oct 14, 2022
  11. An2TheTwan
    97
    New York
  12. An2TheTwan
    97
    New York
    My next question:
    •Refer to video
    about 23:27 seconds in:
    •I need three o-rings, it looks two on the head and one on the short block.
    •Per the photo Mendel posted, are these item# 96721-24015 (Ring, O , For Oil Strainer) ???
    96721-24015 - Toyota Parts Deal
    •Also, is the one on the short block the same part number? The ones I were given from Toyota didn't come in a bag with a part number and I they look too big/skinny:
    •Basically what I'm asking is for the part number for the three o-rings recommended in the video at this step:
    #93 An2TheTwan, Oct 14, 2022
  13. Mendel Leisk
    41,029
    I wish Toyota would publish a parts list for the gasket kit. Maybe they have but I haven’t found. I do have a flakey memory: somone posted a low res print of the numbers, I typed it out one time, but good luck trying to find it. :oops:
  14. An2TheTwan
    97
    New York
    Does anyone have the part number the these o-rings? The ones on/near the oil filter housing:
  15. Mr. F
    Mr. F Active Member
    387
    255
    Washington
  16. An2TheTwan
    97
    New York
    Thank you! You wouldn't happen to know the part number for the three o-rings in this part of this video? (about 23:27 minutes in, but link should take you directly to it)
  17. Mendel Leisk
    41,029
  18. An2TheTwan
    97
    New York
    #99 An2TheTwan, Nov 3, 2022
  19. An2TheTwan
    97
    New York
    Well car is reassembled.
    -When starting Prius in maintenance mode, it runs for maybe 10 seconds or so and then the engine stops working.
    -I have had my car sitting around 3 months.
    -I get the yellow triangle, check hybrid system, then it says low HV traction.
    -Also receiving code P3190
    Is this an issue with the hybrid battery? Is there anyway to fix this without having to change the hybrid battery? My 12v battery also died and was able to charge that overnight. Can you charge the hybrid battery in a similar way?
    *Edit, forgot to include the following:
    -The first time starting my car (normally, not in maintenance mode) - it seemed to run for about 20-30 seconds or so then died.
    -Then I tried running in maintenance mode. It would run for about 10 seconds then stop. It did the same thing a couple more times when attempting to put the car in maintenance mode. Now, after several tries, it won't even run in maintenance mode, it shuts right off.
    #100 An2TheTwan, Nov 3, 2022
