Yellow Circle with an Exclamation Mark?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Black2006, Nov 27, 2006.
  1. Black2006
    Black2006 Member
    198
    Came on a couple of days ago. I know I should have looked at the manual, but it is buried in a box somewhere:-( What is it and how serious?
    2006, Option 9, about 8000 miles, service done at 5500 miles.
    Thanks!
  2. Tideland Prius
    16,615
    What's around the circle?
    Does it look like this?
  3. miwaku
    miwaku New Member
    70
    Not to pick on you, but you have an error message on your car. Might want to dig out the manual.
    Also, just out of curiosity, what the heck is on Pkg 9? 2006 models only had pkgs 1-8.
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Black2006 @ Nov 27 2006, 04:25 PM) [snapback]354614[/snapback]</div>
    Could it possibly be a cross section of a tire and not a circle? If that is the case, one or more of your tires are low on air.
  5. Black2006
    Black2006 Member
    198
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 27 2006, 04:47 PM) [snapback]354618[/snapback]</div>
    Yep, it like a yellow exclamation mark in single parenthesis, with an underline at the bottom.
    As to the manual, I am still in my office, away from the box, and my wife is driving the car.... No weird behaviour, no buzzers or chimes. If it means anything, I installed a second microphone a few days ago, but I can't imagine it would cause the light to come on:-(
    Oh, yes, it's Package 8. What do I know....:)
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Nov 27 2006, 05:50 PM) [snapback]354638[/snapback]</div>
    Is that the (!) with an underline connecting the two parenthesis (hey, that's how my wife is describing it)? It'd be nice if that's all it means:)
  6. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Black2006 @ Nov 27 2006, 06:03 PM) [snapback]354642[/snapback]</div>
    It is if the underline is not smooth, but resembles the cross section of tire threads.
  7. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    one of your tires is low. check tire pressures.
  8. Black2006
    Black2006 Member
    198
    Thanks! Just got home, looked at the warning light, it is the tire pressure sensor:)
    Now I feel a little stupid, but much relieved....
    Thanks again!
