C1345 code not going away
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Omer Afzal, Apr 23, 2021.
Tags:
  1. Omer Afzal
    Omer Afzal New Member
    Pakistan
    2012 Prius Alpha
    Touring + Tech
    Dear All,
    I recently has purchased used prius alpha 2012. It had traction control light on. I got it checked from mechanic and he told me that angle sensor is faulty need replacement. I got it changed. After that light was gone. There were some noise in the suspension of the car. I got them checked the steering assembly was faulty. I got it replaced. However after that alignment was off. I went for alignment which caused the traction control light again came. I called mechanic he told me to reset the code and i mistakenly reset the memory of the ABS. Now C1345 code is coming. I have tried every method to learn the the values but its not getting saved in the system. I am sure that there is some configuration wrong which needs to be correct. Can someone help me in identifying which configuration is wrong and how to fix it. Please help
  2. Omer Afzal
    Pakistan
    2012 Prius Alpha
    Touring + Tech
    Just to add in it i am using the attached method to calibrate the C1345.
    probably i am missing the following steps. Can someone guide how i can do following steps using techstream please help.
    (8) Perform initialization and calibration of the linear solenoid valve.
    (9) Perform the zero point calibration of yaw rate and acceleration sensor
    PriusDadNoob likes this.
  3. danpri13
    danpri13 Junior Member
    Fort Lauderdale, FL
    Do you know a OBD2 scanner tool under $300 that i can fix the C1345?
    Long story short: took the car to check alignment and it was done but when trying to calibrate with the tool, they could not so they recommend to take it to the dealership.
    I did not have any light in my dashboard before, Prius 2013.
  4. PriusDadNoob
    PriusDadNoob Junior Member
    72
    Did you ever fix this? I have this problem.
  5. Bnppp2012
    Bnppp2012 New Member
    Lapel, IN
    I'm having same problem how did u fix this
  6. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Can you describe your problem in detail?
    How did you detect the error - incorrect operation of systems, indicator lights in the car due to errors, reading error codes?
    What device did you use to read error codes?
    Is there a printout with error codes and a freeze frame?
  7. escknx
    escknx New Member
    NOLA
    I can describe since I have this problem after replacing brake booster and pimp twice.
    Done bleeding many times after replacement according to procedure but it couldnt learn linear offset no matter what, during procedure brake light blinks slowly and after 120 seconds stays lit, no fast blink.
    Battery maintainer always hooked up, no air in system, no other codes, tried disconnectiong battery wait then procedure - no luck. Tried with Launch, Autel and Techstream - same result. Accumulator doesn't drop pressure and operates as it should as far as im concerned.
    Brakes work fine, brake pedal feels normal.
  8. Nicholas Koski
    Nicholas Koski New Member
    Rochester mn
    Im having the same issue. I performed an alighment on a customer's car and it walked me threw the reset procedures but im still left with codes c1345. Did you resolve this?
  9. Tim Jones
    Tim Jones Senior Member
    1,755
    565
    SE Texas
    2011 Nissan LEAF
    https://www.ebay.com/itm/395318975337?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=395318975337&targetid=2315428265220&device=m&mktype=pla&googleloc=9027607&poi=&campaignid=21394550841&mkgroupid=173029507588&rlsatarget=pla-2315428265220&abcId=9448521&merchantid=5445642762&gad_source=1&gad_campaignid=21394550841&gbraid=0AAAAAD_QDh8wLC-mSJOq3CBuS9uCvRnez&gclid=CjwKCAjwy7HEBhBJEiwA5hQNoiFh3v1bxr_p-D2pkn9N4aDqHV4qwnP2UyafPeHjyi540eR6FB3hJRoCTD0QAvD_BwE
  10. ChapmanF
    18,069
    The repair manual also gives a "when not using the Techstream" procedure for learning the solenoid offset. Just done with a jumper wire.
    I ended up doing that recently because I wasn't able to do it with my Autel AP200 (for some reason; I'm not saying it had to be the AP200's fault, only it didn't happen to work that time, and I just said "fine, I'll try the jumper way").
    Toyota Service Information and Where To Find It | PriusChat
    When the learning procedure happens, the light does a slow blink for a while and you can hear the car repeatedly applying the brakes with different amounts of pressure and releasing them, and at the end the slow blink turns fast.
    If that stuff doesn't happen, you haven't managed to make the procedure happen.
