1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    What is the best coolant for the engine and inverter?
  2. davecook89t
    davecook89t Senior Member
    1,076
    812
    Washington State, Florida
    Four Touring
    There may be alternatives, but the price difference between them and Super Long Life Coolant from your Toyota dealer is not worth the risk, from my point of view.
  3. BiomedO1
    3,155
    1,668
    SacTown, Ca
    I've also seen chemical reactions occur when people mix coolants. Unless your going to flush-out the entire cooling system with distilled water - I'd just stick to OEM coolant for a quick drain & fill.
    Whatever you save from the cheap stuff at Walmart, you'll be losing in time spent doing the job correctly - IMHO. Then again; if your time isn't worth anything - go for it.....
    davecook89t and Doug McC like this.
  4. Doug McC
    Doug McC Senior Member
    1,055
    402
    Midwest
    2022 Prius
    The Petroleum Quality Institute of America has some helpful information on their website that will help you understand the importance of using the correct coolant in your vehicle.
    Additionally, John Kelly of Weber University and The Car Care Nut both have YouTube videos that will help you understand and make an informed decision on coolants for these vehicles.
    Failure to use the correct coolant will significantly increase your cost of ownership.
    Taxi/Limo likes this.
  5. Mendel Leisk
    40,984
    If you read Toyota's recommendation in the Owner's Manual, you may come to the same conclusion as me. The recommendation:
    I read that, and my conclusion: I'm not bright enough to find a suitable alternative, just stick with the Toyota stuff.
  6. Wraiththe
    Wraiththe Member
    278
    53
    Charlotte NC
    What sucks is Toyota is not open on Sundays. I had to top mine with the asian red/pink 50/50 premix. Hope it does not destroy the engine eventually. The guy at the store said it was OEM. But I trust no one anyway.
