Trick for starting with a dead 12 volt battery?
Discussion in 'Prime Main Forum (2017-2022)' started by ToeJamFootball, Dec 26, 2022.
  1. ToeJamFootball
    ToeJamFootball Junior Member
    17
    I saw on Reddit that there is a way to start the Prime when the 12Volt battery is too low to start it. No jumpstart required. It said that you can use the A/C button on the key FOB to put the car into Ready mode which will charge the 12 Volt battery from the traction battery.
    I don’t want to run my battery down to try this, but can someone confirm if this is true?.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    I have experienced a dead 12vdc battery three times. Each time was because we had failed to properly shut a door, the car thought the door was still open so the interior lights were left on overnight, resulting in a dead battery.
    I have not tried starting the vehicle with the A/C button. I think that is wrong.
    From my research the only method for the vehicle to recharge its 12vdc battery is for the ICE to be running.
    There is no circuitry existing for the HV drive battery to charge the 12vdc battery [though I wish there were].
  3. bisco
    52,348
    can you link that reddit?
  4. Elektroingenieur
    2,515
    3,287
    Three Touring
    This part is true: there is a remote air conditioning feature (Owner’s Manual (PDF), pp. 531–534), and as described in New Car Features (more info), when it is activated, the system main relays are closed and the DC-DC converter operates, so the auxiliary (12-volt) battery will be charged, or at least maintained.
    This part is mostly untrue: if the auxiliary battery is discharged, the remote A/C feature won’t work. Energy from the auxiliary battery (or from the sub DC-DC converter during plug-in charging, or from some other external 12-volt source) is required to operate the hybrid vehicle control ECU and other computers and to close the system main relays, without which the HV battery remains isolated and can’t charge anything or start the engine.
    Depending on which other electrical loads happened to be switched on and the actual state of charge of the auxiliary battery, it’s possible that someone may have observed that the remote A/C feature worked when the car wasn’t able to be started in the usual way, but I’d suggest not to rely on this behavior.
    On the contrary: there is no alternator, and the DC-DC converter, which receives its power from the HV battery, and the sub DC-DC converter, part of the electric vehicle charger assembly, are the car’s only equipment for charging the auxiliary (12-volt) battery.
    RandyPete and Salamander_King like this.
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
  6. Mendel Leisk
    41,858
    A good trick to starting with a truly dead battery, is to replace it. If the death was somewhat premature, research what you can do to avoid that next time, maintenance regimens.
  7. ToeJamFootball
    17
    Thanks for the information. So, lets say the battery is discharged and the car won't start. If you plug in the car temporarily, won't that supply enough 12 volts to allow the A/C button on the FOB to put the car into Ready mode? Then could you unplug the car and start the engine?
  8. ToeJamFootball
    17
    Here is the link :
    Look for the reply to the OP.
  9. bisco
    52,348
    you need a good 12v for the car to start the charging process. if the 12v won't start the car, neither will it allow charging to start.
  10. bisco
    52,348
    not working unfortunately
  11. ChapmanF
    18,497
    If you do add enough charge to the 12 volt battery, then just stepping on the brake and pressing the power button—the usual way of getting into Ready mode—will work just fine, no 'trick' needed.
  12. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
  13. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    It should be fairly easy to at least get a baseline of how the system works with a voltmeter on the 12 volt battery. As long as anyone doing the testing understands that one test and one reading doesn't give much info on how the system performs under all the conditions it can get exposed to. An app that gives 12 volt readings should be just as enlightening as long as the app reading and the voltmeter reading are at least close enough.
  14. bisco
    52,348
    You need an adequate 12v to start charging the hybrid battery and the 12v.
    That pretty much debunks the idea
  15. vvillovv
    4,324
    1,512
    NY
    adequate is the key. and testing is the only way to find that out, per conditions.
  16. Mendel Leisk
    41,858
    That's CDN $'s, likely around $50 USD.
  17. ChapmanF
    18,497
    vvillovv may have meant testing the 'trick'.
    The goal is to get the system main relays to click in and the DC/DC converter to fire up, at which point the 12 volt system is no longer running on the 12 volt battery, and the 12 volt battery is getting a charge.
    Pressing the brake pedal and the power button is the usual way to do that. But the remote A/C button also does that.
    The claim being proposed is that the remote A/C button may still succeed in circumstances where the usual way won't.
    A comparison of the startup current profile drawn from the 12 V battery during the few seconds it takes for the hybrid system to come online (in either method) would be something solid to look at.
    We already have such a thing, done for Gen 2 about a dozen years ago (at least, as of this writing, the page it comes from is shown by Page Info to have a last-modified date in January 2010).
    Maybe the time is ripe for somebody to make the same pictures for a Prime, and both ways, with the power button and with the remote A/C button.
  18. vvillovv
    4,324
    1,512
    NY
    I've got an app that shows some sensor at 14 volts while in ready. I haven't gotten out the voltmeter in a year or two, but last time I checked at the battery terminals I could only see 14 volts right after ready on and only for a few seconds before it dropped back to 12.+ whatever .6 or so iirc.
    So I'm guessing there are probably at least a few sensors in the Prime that not to many of us even know about much less how they work within the system.
  19. Basic-Mammoth4908
    Basic-Mammoth4908 New Member
    UT
    2019 Prius Prime
    This actually worked for me yesterday in my 2019 Prime. I suspect I had lights on that drained the 12-volt. I was about to give up and take a bus or uber to buy a battery when wife saw this post. AC button, could hear the fans running, let it go about 3 minutes, then I was able to start it.
    In my case, the 12-volt is still good. By the time I got home, it was at 78% and I was able to charge it to 100% - maybe an hour. I'll get it tested soon to make sure it is okay.
    Regarding all the reasons that maybe this is not supposed to work.. I'd say just try it for yourself if you are in a pinch. Have you also noticed that the plug-in battery can receive some charge while coasting downhill? I've seen it go from 0 to 30% descending a mountain. Didn't think that was supposed to work that way, yet it does.
  20. Basic-Mammoth4908
    UT
    2019 Prius Prime
    I didn’t even notice the AC remote button until trying this trick the other day. It did work in my case. I heard the fan running, let it go about 3 minutes, then was able to get the normal ready mode and got going. So a field test success. But would be interesting to see actual technical test results as you suggest. My success was with 2019 Prime.
