2015 Prius C Hybrid Battery Warranty
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by alleymadison, Dec 27, 2022.
  1. alleymadison
    alleymadison New Member
    los angeles
    2015 Prius c
    Hello! I have a 2015 Prius C, 110K miles, with the notorious P0A80 code. The car has always run perfectly, and once the mobile mechanic who diagnosed it reset the code, it's been basically fine since.
    Once I got the code, I checked out the battery fan which was covered in a pretty solid layer of dust. I cleaned it, as well as the fan blades themselves, but no idea if that will help or if the battery is permanently damaged. (any advice or anecdotal experience to that end is also appreciated)
    My main question is, does the CA emissions warranty cover my Prius C battery replacement? I've spoken to two different reps at Toyota who have given me two different answers, and I'm feeling a little disheartened and not eager to go to the dealership. I've read conflicting info that the Prius C is and isn't covered. Is there any chance of Toyota making an exception? Any and all help is appreciated!
  2. PriusII&C
    PriusII&C Active Member
    426
    145
    San Jose, California
    My original understanding is 10-yr/150k-mile for Prius, and 8-yr/100k-mile for Prius C. But later I remember reading a post on Prius Chat someone got his Prius-C traction battery replaced under the 10-yr/150k-mile warranty in California.
    2010moneypit? likes this.
  3. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    According to the Toyota Warranty, it's 8 years/100K Miles.
    2015 Toyota Prius C Manuals & Warranties | Toyota Owners
    Page 19:
    Hybrid System
    • Battery control module (battery
    voltage sensor) (8/80)*
    • Battery thermistor
    • Generator
    • Hybrid battery*
    • Hybrid control module (power
    management control module) (8/80)*
    • Inverter with converter*
    • Motor
    • System main relay and battery current
    sensor
    * Covered under the Hybrid System Warranty for eight years or 100,000 miles, whichever occurs first.
    † Warranted until first required maintenance under terms of the California Emission Control Warranty.
    8/80 = Covered for eight years or 80,000 miles, whichever occurs first.
    Federal Emission Control Warranty
    WARRANTY
    Your Warranties in Detail
    But, I thought that the CARB requirements for Hybrid batteries were 10years/150K miles. But, that may be a latter requirement.
    Imho, call up CARB ,and ask them! Plus, get their name, and record the time and Day.
    If the CARB requirement is 10years/150K miles for your car, then ....
    Then, call up Toyota, and tell you talked to XXX YYYY, on AAA BBB CCC.
    Also, get that person's name, and record the data and time.
    And, from talking to Mr/Ms YYYY, you're understanding is that the CARB required warranty on your vehicle is DDDD.
    Is that correct? Or, do you need something in writing from CARB, or to have a CARB official contact them directly?
    Note, always be polite and professional. The person you are talking to does not make the rules, nor do they decide what they can and can not tell you.
    Good Luck!
    nancytheprius likes this.
  4. BrettJohn
    BrettJohn New Member
    Phoenix
    2016 Prius c
    Toyota offers BEV battery warranty coverage for 8 years, or 100K miles, whichever comes first.
  5. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    BEV toyota is a joke. Worse than anything else. Their HSD is marvellous
  6. bisco
    52,286
    they must have really cheaped out if they're only offering an 8/100 warranty
  7. Leadfoot J. McCoalroller
    8,133
    7,631
    Pennsylvania
    2018 Prius c
    The c model was always sold with a shorter warranty on the hybrid battery.
    I've read speculation that the c is a little harder on its battery because it is 86% as heavy as a 2nd generation Prius, yet the battery is 40% smaller, and that adds up to me.
    (2932lbs and 14 blocks vs. 2530lbs and 10 blocks)
    johnHRP likes this.
  8. johnHRP
    645
    189
    KA, DE
    Excel
    I am thinking the same way too. But the warranty for Yaris hybrid with identical powertrain and battery is 10 years/unlimited miles in europe.
    Is it either they are not identical or the weather is milder in EU
  9. Leadfoot J. McCoalroller
    8,133
    7,631
    Pennsylvania
    2018 Prius c
    My guess is that they're all hitting 10 years before they hit any significant mileage, what with Euro cities so close together.
  10. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    For some reason I thought the all Prius hybrid battery warranties (outside of California) were 10yr/100k until a few years ago.
  11. Leadfoot J. McCoalroller
    8,133
    7,631
    Pennsylvania
    2018 Prius c
    I couldn't say. Toyota has the warranty booklets in PDF form on their owner info site, if you want to get to the bottom of it.
    Pri3C likes this.
  12. johnHRP
    645
    189
    KA, DE
    Excel
    The emissions on Prius C is not as low as Prius. So, Prius C is not eligible for 10y/150k miles CA warranty
  13. johnHRP
    645
    189
    KA, DE
    Excel
    Not exactly. Many people live in Germany, France, and Spain commute pretty far. I and most of my colleagues commutes with car 10miles daily. With vacation and hiking trips, we spent 15-20k miles per year. Yet the hybrid battery rarely failed and we all have 10y in europe mainland and 15 y in UK/ireland without mileage limitation. I believe the mild climate is the main reason. Uk/Ireland rainy/cloudy days is 90% in a year. The winter is never really cold either.
