So you shouldn't use oil that has been sitting around unused in the containter ?
Discussion in 'Prime Main Forum (2017-2022)' started by Taxi/Limo, Dec 29, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    I have a half a container unused mobile one 0-20 that has been in the back of the car for a year or so
    Is it unusable now ?
  2. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    I would use it, as long as the vehicle you’re putting it into calls for 0W-20.
    Taxi/Limo likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    IF by "half a container" he means half a quart.......it should not matter what "it calls for" and it will be fine for adding to whatever is in there.
  4. Mendel Leisk
    40,983
    Took a look over at bitog. There’s one mention, that if oil was stored cold enough to freeze something might separate out. Other’n that no worries. And you’re in California.
    I routinely have motor oil in previously opened containers, sitting in garage, 6~12 months. Never gave it a thought.
    With brake fluid and Toyota ATF WS you need to be more careful though: if not used immediately I’d recycle those.
    #4 Mendel Leisk, Dec 30, 2022
  5. aleyoop
    aleyoop Junior Member
    39
    socal
    def use...no issues
  6. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    The stuff is already rather old. An extra few months in a bottle won't hurt anything.
    I regularly save the heels from each oil change to get a free one every so often.
  7. BiomedO1
    3,154
    1,668
    SacTown, Ca
    It's been bouncing around your trunk for a year or so - I'm pretty sure that oil is going to face a much harsher environment when you dump it into your engine block. :)
    Oil manufacturers state one year warranty/change cycle to sell you more oil. Kinda like the expiration date on your bottle of water. I'd pay a little bit more attention to things like that, since I'm consuming it. Before you ask; I do drink expired bottles of water.:D:p:love::LOL:
  8. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    Check the Valvoline website. They say it's OK subject to some caviots. If the bottle was never opened, it's OK. I don't know about a semi-used container though.
    BiomedO1 likes this.
  9. BiomedO1
    3,154
    1,668
    SacTown, Ca
    I've never had an engine dye on me, by putting in partially used containers of oil to top-off my crankcase. "knock on wood":whistle:
    Even when they've been sitting in my garage for several years.
    I have had friends engines die on them, for lack of oil in the crankcase :(:sleep::eek:. She keep driving the car with the oil lamp lit, because she was only 10 miles from home. Bearing and rod knock afterwards; but that 4runner still ran.
  10. Trollbait
    12,436
    It's fine. Yeah, it has seen more exposure to air and water than an unopened bottle, but those really don't start doing anything until the oil hits engine temps.
    The dates on water bottles is because of NJ law, and its cheaper for company to just label all their bottles with such than risk shipping undated to NJ.
