Mixed Info About Inverter Pump Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by newtothisprius, Jan 19, 2023.
  1. newtothisprius
    newtothisprius Junior Member
    59
    Does anyone have any videos they recommend for fixing this issue?
    I ordered the part from Toyota's official dealership and want to do this right the first time.
    Some guides say you need to bleed the system and some say you don't because it does it for you.
    I'm not sure which option is the correct one.
    This link doesn't feature any bleeding of the coolant:
    Same with this one:
    #1 newtothisprius, Jan 19, 2023
    Tombukt2 likes this.
  2. ChapmanF
    19,025
    The Gen 2 inverter cooling system comes with a bleed valve. If I had just drained and refilled some coolant, I can't think of a reason I wouldn't use it.
  3. Tombukt2
    13,861
    2,519
  4. newtothisprius
    59
    Sorry guys but I'm not understanding your posts.
  5. newtothisprius
    59
    Is it necessary for me to bleed the system or can I change out the pump right now and do that another time? I've got the car disassembled and no coolant because the videos didn't show that I needed one.
  6. ChapmanF
    19,025
    The system comes with a bleed valve for a reason. If you have let coolant out, say to replace the pump, and then refilled the coolant, there may be air inside. Use the bleed valve and the procedure in the repair manual to get the air out.
    newtothisprius likes this.
  7. newtothisprius
    59
    Am I allowed to replace this inverter pump now though and then do that?
  8. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    Easiest bleed valve I've ever used... Just connect a small hose from the bleed valve to the reservoir and open it up and wait for the bubbles to go away. Very well designed!
    lunarkingdom likes this.
  9. newtothisprius
    59
    But can I remove this inverter pump, replace it with the new one, and then do that?
  10. bisco
    52,855
    yes, that would be the recommended proceedure. you can''t bleed the system before removing and installing the pumps.
  11. newtothisprius
    59
    Lol thank you for answering this question for me. I've been trying to get an answer before committing to this. Now I can.
  12. newtothisprius
    59
  13. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The rusted bracket is identical to the bracket that will be already installed on the new pump. Most people remove the new pump from the new bracket and just install the new pump on the old bracket. Yes, your old bracket is impressively rusty. Yes, the threaded holes appear to still be there, but the integrity of the bracket is in question. If you're up for it, then remove the old bracket, and then install the entire new assembly. If you're not up for it, then do it the same way as most do it....new pump on old bracket and it is what it is.
  14. lunarkingdom
    lunarkingdom Junior Member
    59
    southern California
    Sand the rusted area with sand paper to remove any high spots then use some rust converter on the sanded/rusted spits it will turn the rusted areas black and keep them from rusting in the future. Then install the new pump and proceed to bleed it and enjoy your new pump ;-)
    EDIT: use the new bracket suggested above if available.
  15. ChapmanF
    19,025
    Once you replace the pump, put coolant back in.
    Do not run the car without coolant.
    When you put the coolant in, you use the bleed valve and get the air out. It's part of that job.
  16. PriusCamper
    13,465
    5,431
    Yes... and if you don't want to waste coolant you can clamp the hoses and swap pumps... It's way less hassle that way!
  17. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    what priuscamper said. If you clamp the lines only a bit of fluid will be lost. I cheated and added an ounce or two of water to bring level between the lines. The bigger pain is having one of the mounting bolts break off leaving a stub in the chassis. Then you better find someone to help drill out the broken bit.
  18. newtothisprius
    59
    Anyone have any guides to remove and install the bracket? YouTube seems to all have people who just replace the pump. Thanks.
  19. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    Well, the bracket is attached by two fasteners. There's a 6mm bolt that goes into the side of the frame rail. I think it also holds the bracket for the 3-way coolant valve. That bolt usually comes right out, no problem.
    The other fastener is a vertical 6mm stud and nut that is at one corner of the underhood fuse box. That nut is "always" seized and has snapped every time. Tried a number of techniques, still breaks. Now I leave it alone and reuse the old bracket- if possible.
    Or break it. Then move the new bracket a little over and use a self drilling sheet metal screw.
  20. newtothisprius
    59
    That's the answer I needed. The bolt did look simple but I couldn't figure out what the other "screw" was. It looked like a torx screw.
