How many miles on your Gen 3 and what Repairs / Maintenance have you done?
Discussion in 'Gen 3 Prius Main Forum' started by Michael Wood, Oct 22, 2020.
  1. Bill Norton
    Bill Norton Senior Member
    1,810
    591
    MONW, Ks.
    Keep in mind all the recommendations posted here are possibly Prius Folklore.
    Every 50k miles you pop the hood and spend hours and hours (days?) cleaning this system?
    That's approaching helicopter 'Maintenance hours / Flying hours'... (Not really,;) but this is a lot more than most cars.)
    And to what end?
    Has there been reputable reports of Gen3 Prius owners that do all this 'Preventative Maintenance' and the head gasket is holding in there at +250k miles?
    All these 'Preventative' Ideas are talked about a lot on this forum, but Toyota remains silent on the subject of Gen3 head gasket life span.
  2. taxidriver50005
    taxidriver50005 Active Member
    204
    169
    GB
    Excel
    2012 gen 3 now with 345,000 miles, no burning of oil whatsoever.
    I put this down to doing a engine flush every 3rd oil change, this flush cleans the piston rings and stops them sticking which in turn stops it burning oil which has a good effect on the EGR by not clogging up. Battery had done well till 340,000 then got the dreaded triangle of death, did a refurb myself replacing 4 cells and all is good now. Only other items replaced have been shocks, anti roll bar D bushes and brakes and tires.
    Also 10,000 mile oil changes here using cheap fully synthetic oil.
    #222 taxidriver50005, Jan 25, 2023
    xliderider, mjoo, Noahdoge and 3 others like this.
  3. ChapmanF
    14,975
  4. taxidriver50005
    204
    169
    GB
    Excel
  5. taxidriver50005
    204
    169
    GB
    Excel
  6. CR94
    CR94 Senior Member
    2,642
    1,133
    Northwestern S.C.
    Further evidence that, contrary to popular folklore, these cars don't all become oil burners and clog the EGR cooler as soon as they pass 100k miles. Mine hasn't either (yet!), albeit at only about 40% of your mileage.
    bettergolf and Noahdoge like this.
  7. ChapmanF
    14,975
    and without following the link I put there, perhaps you never will!
  8. Noahdoge
    Noahdoge Active Member
    165
    118
    Mississippi
    Very impressive! What brand oil flush product do you use?
    Bill Norton likes this.
  9. Mendel Leisk
    38,105
    I’ve got a hunch @taxidriver50005 has intervened with his EGR once or twice.
  10. taxidriver50005
    204
    169
    GB
    Excel
    I originally cleaned EGR system at 140,000 miles and haven't touched it since, I am tempted to pull it apart just for the hell of it but if it ain't broke!!!
  11. taxidriver50005
    204
    169
    GB
    Excel
    Liquid molly engine flush pro, about £10 a tin in the uk Screenshot_20230126_091147_eBay.jpeg
    douglasjre, Bill Norton and Noahdoge like this.
  12. taxidriver50005
    204
    169
    GB
    Excel
    I had never used the car scanner app before so hadn't a clue on what's good and bad on the flow side but here goes, 204520 miles since last EGR clean.
    CR94 and Bill Norton like this.
  13. taxidriver50005
    204
    169
    GB
    Excel
    My wife also has gen 3 prius which we bought as an oil burner with 190,000 miles.
    Treated it to a piston soak with same engine flush solution while we went on holiday then did engine flush as well, end result car does not need topping up between 10,000 mile oil changes
    refusedone and Bill Norton like this.
  14. Mendel Leisk
    38,105
    Check the pipe between EGR valve and intake manifold at the least; if it’s bad the rest is likely worse.
  15. Bill Norton
    1,810
    591
    MONW, Ks.
    Amazing mileage ! Thanks for the info!
    Did you buy the car new?
    If not it might be that it has already had a head gasket issue and the replacement head gasket was the Felpro.
  16. Bill Norton
    1,810
    591
    MONW, Ks.
    What was the piston soak product you used?
    And this 'flush solution',, do you drive X miles with it in the oil, then change the oil?
    What are the instructions on the flush solution?
  17. CR94
    CR94 Senior Member
    2,642
    1,133
    Northwestern S.C.
    That's interesting. What engine oil are you using, at what oil change intervals?
  18. CR94
    CR94 Senior Member
    2,642
    1,133
    Northwestern S.C.
    Have the EGR components ever been cleaned, or the head gasket ever replaced?
  19. ChapmanF
    14,975
    OK, 12.92 is getting down there. Squeaky-clean is usually up around 21 or 22. Mine was down to 10 point something before I cleaned it. Yours might be about due again.
    Of course it can still go a lot lower before hitting the failing value and setting P0401. Whatever you're comfortable with.
    Another possible cause of a low test score is a mashed ski jump in the EGR valve rotor. Also worth checking.
    douglasjre likes this.
  20. taxidriver50005
    204
    169
    GB
    Excel
    Wife car 245,000 miles, cleaned 50,000 miles ago..... To be fair I cleaned up EGR cooler really well but only scraped out the manifolds on both cars. Screenshot_20230126_170234.jpeg
