Odometer limited to 299,999 miles
Discussion in 'Gen 2 Prius Technical Discussion' started by 80Kayear, Aug 24, 2009.
  1. Mendel Leisk
    41,859
    It seems to me Toyota owes owners a decent solution. Re-zeroing the display, with a secure sticker explaining what's been done, for example. Coupled with some documentaion.
    DIY hacking the software to rollback the odo sounds like a Pandora's Box, best left alone, for legal reasons.
  2. Desertdeals69
    Desertdeals69 Junior Member
    44
    Lk Havasu City Az 86403
    I bought a 07 with 359,000 + miles on the odometer. It was a Las Vegas taxi.
  3. The Tramp
    The Tramp Italian Prius Expert
    376
    52
    Turin, Italy
    2020 Prius PHV
    Yes, mine just froze at 299999 km.
  4. NatxoPrius
    NatxoPrius New Member
    Sabadelk
    I am stuck also at 299.999 and mine is 2004 (it is spanish so mine are km).
  5. Danny13pruisc3
    175
    27
    maryland
    i was hoping this thread would be more helpful like telling you what you could swap out from the junkyard with a newer model to start getting mileage again
  6. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    My recollection from reading a while back is that you can buy a remanufactured display with the higher limit. I think the guy was in TX.
  7. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Look up Texas Hybrids and call Matt. Great guy. He can send you a reconditioned combination meter with a lifetime warranty. You'll actually have to change 2 circuit boards to upgrade to the 06-09, but everything works fine. You have to pull the dash out completely to get to them.
    donbright and Another like this.
  8. JDonovan
    JDonovan Junior Member
    CT/PA
    Happy to know there isnt anything wrong with my car……hit 299k a couple weeks ago. Did anyone have trouble with insurance? Or registration? Places where you must list your mileage!?! Doesnt sound like there are any easy fixes?
  9. Mendel Leisk
    41,859
    Good point. Up here you can get a 10% discount with the main auto insurer (Insurance Corporation of British Columbia, aka ICBC), if you can prove yearly kms are under 5000. With typical insurance that's at least $100 you'd be missing out on...
  10. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    The easiest fix is the one mentioned in the post above yours.
  11. pasadena_commut
    pasadena_commut Senior Member
    2,796
    832
    Southern California
    Is it even legal in the US to sell a car where the odometer self destructs like that? Somehow I don't think so. I know it is OK if the odometer rolls over to 0, at least in CA, so long as a permanent plaque is affixed somewhere to show that one must add 100K (or whatever) to whatever is shown to get the true mileage.
    I know that Toyota has a way to reset the odometer mileage. When the cap failed (while under a warranty) Toyota replaced that board in the dash, and they set the replacement unit to the mileage of the previous time I had come in for service. So my odometer is about 300 miles lower than the actual mileage. Anyway, the point was, they did have some way of setting that number on the board. Sadly, to do so the entire dash needs to come apart to reach it. (When they did that service they botched the reassembly, failing to reconnect the air routing control wiring, so I could direct the air down, or to the windshield. So back it went to fix that too.)
  12. Salvatore78
    Salvatore78 Junior Member
    France
    Has anyone tried this?
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    That doesn't "reset the odometer to 0". That resets the mileage counter for the Maintenance Required light.
