Lights Differences: LE vs XLE
Discussion in 'Gen 5 Prius Main Forum' started by Perpetual Waffle, Feb 25, 2023.
  1. Perpetual Waffle
    96
    120
    Wisconsin
    2023 Prius
    XLE AWD-e
    Found a Reddit post that had some interesting images regarding differences in headlights, taillights, and turn signals between the LE and XLE trims and thought I would share. Figured the forum would like to discuss. :D
  2. Gokhan
    Gokhan Senior Member
    6,476
    2,593
    Paramount CA
    Interesting. Turn signals are really different?
    When did Longo get a bunch of 2023 Priuses? The inventory never showed it.
    Not the matte vs. glossy black bumpers on the LE vs. higher trims, respectively.
    It looks like all LE units have parking sensors after all. This is great!
    #2 Gokhan, Feb 25, 2023
  3. Perpetual Waffle
    96
    120
    Wisconsin
    2023 Prius
    XLE AWD-e
    I’m honestly surprised by the turn signal. The Reddit OP did not elaborate on it at all—you’d think it would be the same across all trims because, really, it’s kind of safety feature.
    I did not see anything on their website, either. I’ve noticed a lot of Priuses showing up on the Toyota.com search, but they aren’t showing on the dealer website.
    Gokhan likes this.
  4. dctalk523
    dctalk523 Member
    The OC
    Uh oh dont you have a deposit with Longo?
    Gokhan likes this.
  5. Gokhan
    6,476
    2,593
    Paramount CA
    Yes, but for a black Prius Prime SE.
    It is their parking structure right. They have a 600,000-ft² parking structure (400 ft by 300 ft by 5 levels) where they store their vehicles.
    #5 Gokhan, Feb 25, 2023
  6. Gokhan
    6,476
    2,593
    Paramount CA
    Here is the link to the Reddit post, where you can view the full-resolution images. All have "sold" signs on the cars.
    These are the light differences:
    LE:
    • no bumper lower-corner accent light
    • headlight lower accent light sits lower and also serves as a turn signal
    • headlight upper accent light does not serve as a turn signal
    • center brake light does not light when brakes not applied
    XLE and Limited:
    • bumper lower-corner accent light
    • headlight lower accent light sits higher and does not serve as a turn signal
    • headlight upper accent light serves as a turn signal
    • center brake light lights even when brakes not applied, albeit in lower intensity as a taillight (How is this DOT-legal??)
    We will see how the Prius Prime SE will differ from the Prius Prime XSE and XSE Premium.
    Dark blue looks better than silver.
    #6 Gokhan, Feb 26, 2023
    TGrracie, bisco and Perpetual Waffle like this.
  7. Gokhan
    6,476
    2,593
    Paramount CA
    This is not street-legal according to DOT/NHTSA:
    Center High-Mounted Stop Lamps (CHMSL) have been standard equipment on all new passenger cars manufactured on and after September 1, 1985 for sale in the United States. They are required by an October 1983 amendment [11] of Federal Motor Vehicle Safety Standard 108 [5]. CHMSL have also been standard equipment on all new light trucks (pickup trucks, vans and sport utility vehicles) manufactured on and after September 1, 1993 for sale in the United States, following an April 1991 amendment [12] of FMVSS 108. CHMSL are red stop lamps mounted on the centerline of the rear of a vehicle, generally higher than the stop lamps on the sides of that vehicle. They are activated when the driver steps on the brake pedal and they are off at other times. The purpose of CHMSL is preventing crashes by reducing the reaction time for drivers to notice that the vehicle in front of them is braking.
    https://www.nhtsa.gov/sites/nhtsa.gov/files/documents/chmsl_complete.pdf
    If someone pointed this out to the NHTSA, there would be a recall to turn this light off on the XLE/Limited/XSE/XSE Premium.
  8. TGTGUUD
    TGTGUUD Member
    96
    72
    San Francisco
    2024 Prius
    Is it possible that center light bar is not a CHMSL?
    Tideland Prius and Gokhan like this.
  9. Gokhan
    6,476
    2,593
    Paramount CA
    It is in my Gen 4 Prius Prime, and I except it to be the same in the Gen 5 Prius/Prius Prime.
    TGrracie and Tideland Prius like this.
  10. Tideland Prius
    16,604
    Yeah. No.
    Buddy up there doesn’t know about light bars which is the current de rigueur in vehicle design. Look at all the new vehicles - they have a rear light bar.
  11. mountaineer
    mountaineer Active Member
    146
    115
    Hamilton, ON
    2019 Prius Prime
    How are light bars not in violation of this policy?
  12. TGTGUUD
    TGTGUUD Member
    96
    72
    San Francisco
    2024 Prius
    There is an additional CHMSL above the emblem, the light bar is below and at the same height with the brake lights (meaning it does not qualify as a CHMSL according to the regulation you posted). So it is not the same.
    GuyLR likes this.
  13. Gokhan
    6,476
    2,593
    Paramount CA
    If you look at 2022 Kia Stinger, it is the identical design as the Gen 5 Prius XLE/Limited, but there is a CHMSL inside the top of the rear window. Gen 5 Prius does not have it. Therefore, the light bar is not supposed to light unless the brakes are applied.
    The light bar is not supposed to light unless the brakes are applied because it is meant to be the CHMSL. This is the case in Gen 4 Prius Prime and Gen 5 Prius LE but not Gen 5 Prius XLE and Limited.
    Perhaps there is a separate CHMSL, but I haven't seen it.
    #13 Gokhan, Feb 27, 2023
  14. Trollbait
    12,653
    Can't spot it in the OP photos with the low lighting.
  15. Gokhan
    6,476
    2,593
    Paramount CA
    Good find.
    Perhaps the bulb on the light bar of that LE is burned out. ;)
    #15 Gokhan, Feb 27, 2023
  16. Tideland Prius
    16,604
    Because it's a taillight, not a brake light.
    Reading the quote from Reddit again:
    "center brake light lights even when brakes not applied, albeit in lower intensity as a taillight (How is this DOT-legal??)"
    Does that make sense to anyone? "centre brake light lights up even when brakes not applied..." That's because it's NOT a brake light. That's the definition of a tailight. And the "albeit in a lower intensity as a taillight" is exactly it. It's a taillight. The CHMSL in the Gen 5 is a small light mounted on the tailgate.
    False. The centre solid light on the Stinger is the taillight. The individual LED bulbs below are the brake lights. Here's the taillight without the brake lights on. You'll see that the row of LEDs below the lightbar is off.
    Again, false.
    The Prime does NOT have a light bar. You see in the image below that the centre light that you refer to (mistakenly as a light bar) is off.
    I can see where the confusion lies where because the Prime has a CHMSL that mimics a light bar, one thinks the Gen 5's lightbar is the CHMSL but it isn't.
    No, it just doesn't exist. It's to distinguish between the LE and XLE/Limited models. At night, it'll be easy to identify the Gen 5 trim level based on lighting. (Same as Gen 4 with the Touring models vs. non-Touring - they have different parking light designs)
  17. Gokhan
    6,476
    2,593
    Paramount CA
    This was already pretty much settled after @Trollbait found a pic with the CHMSL.
    Tideland Prius likes this.
  18. Gokhan
    6,476
    2,593
    Paramount CA
    Could it be that the CHMSL on the Gen 5 Prius LE is located inside the light bar like in the Gen 4 Prius Prime? That would be a better design than the tiny CHMSL located just above the light bar on the Gen 5 Prius XLE and Limited.
    Here are the taillights, light bar, and CHMSL on my Gen 4 Prius Prime. It is a better design than the minimalistic Gen 5 design that is a simple straight line in my opinion.
  19. MScelery
    MScelery Junior Member
    83
    24
    Mississippi
    Reviving an old thread before I make a purchase online without seeing the vehicle…
    which version of headlights/taillights does the nightshade have?
  20. KMO
    KMO Senior Member
    2,004
    729
    Finland
    2023 Prius Prime
    The nightshade is a modified XLE trim, with the integrated DRL and front indicators, and the rear light bar.
    Review video confirming that:
    MScelery likes this.
