Resetting works for a little while, but should I just bite the bullet on a new battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tayder314, Feb 22, 2023.
  1. Tayder314
    Tayder314 New Member
    GA
    Hi folks, I’m looking for a little bit of advice here. I’m pretty sure I need a new hybrid battery. My 2010 Prius is at 180,000 miles and my check hybrid system light comes on regularly every day. If I pull up my scanner app I can reset or clear the fault and it seems like the battery works again, but then it just stops working so I’m pretty positive the battery is going bad.
    Can somebody with more knowledge about batteries tell me why it seems to work sometimes, but then just stops until I clear the fault? What is going to happen if I just keep clearing it, will the battery gets worse and worse?
  2. PriusCamper
    PriusCamper Senior Member
    12,989
    5,283
    Pacific Northwest, USA
    Keep your eye on temperature of battery pack, as that's the limit on how often you can clear the warning lights and keep driving. Once it gets super hot, you'll have more expensive hassles.
    As for repair, from least expensive to most expensive we can walk you through DIY module replacement & reconditioning, replace the pack with used rebuilt w/warranty, Lithium Upgrade pack or OEM pack...
    If you want to improve MPG and have better AC in summer and travel much further in EV mode you'll want to buy a Lithium Upgrade pack. If you use my affiliate link I can offer you unlimited tech support: https://projectlithium.com/?ref=9qLPw
    #2 PriusCamper, Feb 22, 2023
    Tayder314 likes this.
  3. Mendel Leisk
    41,829
    Try Dr Prius app (works good with Carista BlueTooth OBD dongle), see what it thinks.
    Just the static test, you get a display that looks like this:
  4. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    What app are you using, and what are the trouble codes shown in the app.
  5. ChapmanF
    18,458
    By the way, if you've done this over and over and not yet written down what trouble code you are resetting when you reset it, that would be worth doing the next time, and then you can post here with what the code is.
    You might be right in guessing it's about the battery, but they aren't all, and that's a very basic first thing to check.
  6. Tayder314
    GA
    i’m waiting on a new reader to come in the mail that works with the Dr. Prius app but here’s what my current fault code is. F42CCFE8-258B-4C18-8F22-ACF42EB7E64E.png
    Thank you for your help!
