Engine doesn't start to charge hybrid battery in heavy traffic/parked only.
Discussion in 'Gen 2 Prius Main Forum' started by Rick 432, Mar 10, 2023.
  1. Rick 432
    Rick 432 Member
    112
    29
    I have a 2007 (3) Gen 2 with 70850K. The hybrid battery is family new and has been tested at 93% "new." The 12v battery is also fairly new. Here is the issue.
    When I am in traffic (a stopped situation), the engine does not come on to charge the hybrid battery. I first noticed this a week or so ago when I was stuck in traffic due to an accident ahead of me. The battery was depleted and the color on the screen turned pink at 2 bars. Luckily, the traffic opened up. As I moved forward, I noticed the engine start up and the battery was charged. Today I was in a parking lot with the car on, ac on and parking brake on. I was checking something on my phone. After 10 minutes or so, I noticed the battery was very low. It went to pink again. I moved into traffic and the battery charged itself via the engine. Clearly, there is an issue with the hybrid system telling the engine to start and charge the battery. When I start the car in the morning or at anytime for that matter, the indicates Ready and within 15 seconds the engine will fire up. The car has had no issues. I see no codes and there are no idiot lights on. Last month, I checked the health of the battery using Dr. Prius. Other than that, there has been no work done to the car with the exception of an oil change, transmission fluid change and brake fluid change. Any help would be appreciated. Thanks guys!
  2. Tombukt2
    13,274
    2,396
    Are you pulling off and making the car start a second before it would start anyway? I haven't tried this in my car recently I will It's an '09 same car basically.
  3. Rick 432
    Rick 432 Member
    112
    29
    No. If I drive the car normally, the battery will remain charged. If I get into heavy traffic in basically a stopped situation, the battery will deplete to a point where the indicator turns pink. If I recall correctly, when the car is in a stopped situation ( traffic or parked), the engine will engage to replenish the battery. This is not occurring. I noticed today as I was driving the car, the engine would engage but when the car is stopped the engine will not. Also, as I mentioned, when I initially start the car, after 15 seconds or so, the engine fires up as it always did.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Are you leaving it in gear........or have you recently started putting it in Park when stopped ?
    I have noticed that my C works differently when in Park but still "running".
  5. Tombukt2
    13,274
    2,396
    No my Gen 2 sitting in a parking lot say with the air conditioner running which I never do but I have done it before just to watch what happens. In my situation and near 100° weather in Central North Carolina I'll be sitting in the car in the parking lot with the air conditioning on the car and park me preoccupied with God knows what and then after I don't even know how long 8 9 minutes something like that maybe a little less the engine will just come on I don't even look up at the display or I don't have it or I'm not paying attention to what the battery monitor is saying but it gets very close to the first lines of magenta and by the time I noticed that on the display the engine is fired up already and the magenta is turning to blue It's almost as fast as I say it. And it'll do this as long as I'm sitting there in that spot with a load on air conditioning something.
  6. bisco
    52,278
    If the engine doesn’t start, the battery will die, so i think it’s operating normally
    Rick 432 likes this.
  7. Rick 432
    Rick 432 Member
    112
    29
    When the car is in heavy traffic or stopped for a prolonged period of time, the battery is depleted. The engine must start to charge the battery up. I'm thinking there must be either a bad relay or a programming issue. These cars are very complicated.
  8. bisco
    52,278
    idk what you mean. the battery can't start the car if it is depleted?
    in the 3 pri i've owned, the battery always drops to 2 bars in stop and go traffic. then, the engine eventually fires for a minute or three
  9. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
    I really hope that you dont put the car in NEUTRAL when you are parked for long. The car wont charge hybrid battery when in neutral.
    Alternately, use an OBD2 and see the exact SOC. It isnt necessary that as soon as the car hits the 2 bars, the engine will start
    Brian1954 likes this.
  10. dolj
    dolj Senior Member
    8,520
    4,323
    Wellington, New Zealand
    This sounds like totally normal behaviour to me unless you are saying that if you just remain stopped the battery drops to one pink bar then no pink bars and the engine never comes on to charge the battery back up to the third (blue) bar.
    Tombukt2 likes this.
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    Oops. I meant to say NEUTRAL.
    It might be a little different in PARK but it doesn't charge at all in N.
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,076
    1,992
    NJ-USA
    That's normal behavior. The car won't "waste" gas by keeping the HV battery charged up if you're not going anywhere.
    Drive at a steady cruise and the battery "gauge" usually stays at 6-7 bars depending on your terrain. When you're moving the hybrid control ecu aims for about 65% State Of Charge.
    In bumper to bumper traffic, or remain "ready" while parked, the ecu will let the SOC go down to around 45% (1-2 bars) before starting engine just long enough to charge maybe 1 bar.
    Brian1954 and CR94 like this.
  13. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    True. "P" is the same as stopped in "D," as far as charging is concerned. It can't charge while stopped in "N." That would require delivering mechanical power, hence torque, to motor-generator #1 (aka, MG1) through the transmission's planetary gearset---which is inherently incapable of transmitting power to its gear that's connected to MG1, at the same time zero torque (the definition of "N," pretty much) is delivered to its gear that's connected to the wheels.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    True to a degree.
    But none of mine have ever gotten THAT low before starting to charge.
  15. bisco
    52,278
    It may depend on the health of the battery
  16. dolj
    dolj Senior Member
    8,520
    4,323
    Just to refresh my memory, how many Gen 2s have you owned or driven?
    For a Gen 2, just sitting it will not start the engine to charge until it reaches the second (from the bottom) bar which is colored purple (or some call it pink). and will charge only charge up until the third bar (or first blue bar). So, yes, it is normal behavior for a Gen 2.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    STUFF IT. :mad:
    Some things are the same and some aren't.
    So, 16 replies in and we get the right answer.
    Apparently he just had not noticed it before ??
    Pretty typical for a "conversation" but it can be done without insults.
  18. Rick 432
    Rick 432 Member
    112
    29
    What my car is doing is it depletes to the two bars, then the color of the bars changes to a pink but the engine does not fire up. I understand what you wrote about the car starting up and charging the battery. I have been in heavy traffic in the Orlando area and the engine always fired up. No codes and the car seems fine otherwise.
  19. bisco
    52,278
    Is that an oem hybrid battery?
    I can’t remember my 2008 behavior exactly.
    If it started while my foot was on the brake, after I released it, or when I stepped on the accelerator.
    Dolj drives one and should know exactly .
    If it’s not the battery, might be an ecu or corrosion
  20. Fred_H
    Fred_H Misoversimplifier
    560
    485
    28
    Germany
    Under certain conditions, it is normal for the battery display to get down to one bar before the engine starts to recharge it. With just one bar remaining, it is actually not even close to being "depleted", still having at least 40% State of Charge (SOC). See the following illustration:
    But it does not always go down to one bar before the engine starts to recharge it. There are several things, and combinations of things, that can cause the engine to start before it gets down that far. For example, engine coolant temperature too low, battery temperature too low or too high, HVAC temperature setting too low or too high, defroster setting, catalytic converter temperature too low, and maybe some more parameters that I am not aware of.
