EGR Cleaning at Hybrid Pit
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MelonPrius, Mar 31, 2022.
  1. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Can anybody recommend an experienced shop in the SF Bay Area, East Bay that can do this work for a reasonable price like Hybrid Pit?
  2. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    Reasonable price?….Bay Area?….haha, good one
  3. HarvMilt
    HarvMilt New Member
  4. HarvMilt
    HarvMilt New Member
    But really. I’d drive the 500 miles to Orange County, but are there any shops of their caliber in Northern California? I’m in the Sacramento area. 2015 Prius 2, 132k miles, running great, but it’s a mystery to me and I leave magic to the pros and you savvy owners.
  5. MikeDee
    1,580
    597
    Gasket Masters is in Manteca CA, an hours drive from me.
  6. RightOnTime
    RightOnTime Senior Member
    790
    1,660
    183
    Kidnapped in OC, CA
    Another Car that made the trip from Northern California to HP. Car was trailered for an Engine swap, EGR service and AC service
    Xterra72 likes this.
  7. Mendel Leisk
    41,761
    What’s the miles on it?
    Regarding the engine bay pic, besides the missing Toyota emblem (on plastic cover atop engine) maybe suggest the (Lexus p/n 82821-76010) wiring cover:
    #67 Mendel Leisk, Jun 26, 2023
    RightOnTime likes this.
  8. ASRDogman
    ASRDogman Senior Member
    7,715
    3,958
    Where is hp? The computer maker?
  9. Mendel Leisk
    41,761
    Hybrid Pit. I struggle with this stuff too.
  10. rjparker
    10,365
    6,488
    Come on! HP gets discussed several times a week around here. The better alternative to JDM when a transplant is needed. I would have them ship to my local discount shop.
  11. ASRDogman
    7,715
    3,958
    If they bore the cylinders, then they are too thin. Where do they get the larger
    pistons and rings?
    "iffy" if felpro is better than a Toyota head gasket. Do they use a thicker head gasket
    to make up for the lost material of the head, and block? Which would increase the compression.
    And bring the piston and valve closer to each other.
    Does the head gasket have a second sheet of aluminum in it to make up for the cut material
    to keep the correct compression?
    I'm not saying the engines are not "remanufactured" well or incorrectly, just wondering if they
    are taking all that into consideration.
    With jdm, who knows what you are getting? If it fails, what warranty do they have? How long do you
    have to wait for another engine? How long for the first one?
    Do either place pay for the labor and parts in replacing the defective engine?
    Georgina Rudkus likes this.
  12. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    Little over 180k, we have those in stock at HP
    iPhone ?
  13. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    We just finished putting some long Miles on our Frankenstein engine build Needles to say but this may be a bullet proof motor using components off a Toyota Hybrid motor not offered in the States.
  14. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    Very good questions……
    We offer several packages for people that are on a budget
    Bronze - stock cylinder bore using new Toyota Piston rings
    Gold - stock cylinder bore using revised Toyota Pistons and Piston Rings
    Performance - .20 bore size with Larger Pistons and Piston Rings
    Platinum - Toyota Zero mile block with upgraded Pistons and Rings installed by Toyota
    Frankenstein - still in development, using many components from a Toyota Hybrid engine from Japan with different shape pistons using stock bore.
  15. ASRDogman
    7,715
    3,958
    Repeat/updated:
    If they bore the cylinders, then they are too thin. Someone menchioned Toyota doesn't
    recomment boring because the walls are too thin. Do they put in new sleeves?
    Where do they get the largerpistons and rings?
    Do they use a thicker head gasketto make up for the lost material of the head, and block?
    CR94, RightOnTime and Georgina Rudkus like this.
  16. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,491
    2,467
    Taylors, SC
    If I had real money to spend and if my car was from a state outside of the rust belt, I might go for a NEW genuine Toyota short block and a NEW head gasket instead of an engine rebuild like this one done by the Car Care Nut in his video.
  17. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    Wish you lived close to the shop in SoCal, we would love to show you how the process is done and to get a hands on approach of what we do.
    ASRDogman likes this.
  18. ASRDogman
    7,715
    3,958
    That would be great! I would love to see that!
    But what worries me, you are not answering the questions..... (n):whistle:
  19. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    It’s not answering your questions, but we do a lot of R&D seeing what works and what does not.
    Since we are located in SoCal we have many prototypes out in the field for various testing to see how far we can stretch the envelope.
    Many Shops don’t have the resources to do what we do and may not want to go out of their comfort zone but it’s all about ‘Passion with Perfection’ which we do best!
  20. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    That’s out Platinum package minus 2k
