2011 Prius not charging 12V system
Discussion in 'Gen 3 Prius Main Forum' started by georgefrank, Apr 6, 2023.
  1. ChapmanF
    18,560
    Well, the easier question would be "where are the only two fuses that don't control the 12V side?" You don't have to think about those two (one's in the battery service plug and one's inside the inverter). All the other accessible fuses in the car are on the 12V side, and getting to IG ON depends on several different circuits. The wiring diagram, and the repair manual for troubleshooting steps, can be found as described here:
    Toyota Service Information and Where To Find It | PriusChat
    The 125 amp DC/DC fuse buried inside the front fuse box is a nightmare to get access to. There are some accessible points where it can be easily tested with a meter though:
    That photo is from this post, which has more details.
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,077
    5,306
    Pacific Northwest, USA
    Perhaps they should check the fuseable link?
  3. ChapmanF
    18,560
    I'm pretty sure if they follow the post linked in #21, they will. :)
  4. rjparker
    10,533
    6,616
    First, more input from you. When you press the Power button twice does the dash light up?
    Do you still have the normal Prius 12v battery in addition to the one you added next to your 12-120v inverter?
    What power related things work? Lights? Horn? Radio? Be specific.
    How proficient are you with electrical troubleshooting? Do you have a voltmeter and know how to check voltages? Can you read a simple power diagram and trace voltages?
    Do you have the funds to buy parts or tools to fix this car? Lets say you need a $200 battery and a $300 engine fuse box. Or a $500 used inverter? Or a $500 water pump?
    Do you have experience that is relatable to changing a water pump or inverter?
    Does this drawing make sense to you?
  5. georgefrank
    georgefrank Junior Member
    83
    earth
  6. georgefrank
    83
    earth
    https://youtube.com/shorts/Y7XkyMsEKcQ?feature=share
    I did exactly what you guys said, check the voltage at that location, and nothing showed up
    the fuse (140A) at the 12V battery looked beat up but fine
    Those 3 small fuses (mine has 2) all did not show voltage (not videoed)
  7. georgefrank
    83
    earth
    I guess the next step is to get to that 125A fuse (the one you guys said is hard to get to)
    I'll read that other post and see if it shows how to do it
  8. rjparker
    10,533
    6,616
    That test point proves nothing if you don't first check power upstream of the 125a like the fuse box jump point. See diagram. The attachment in my post above shows you how to visually inspect the 125a.
  9. georgefrank
    83
    earth
    Somehow Prius is back on
    I must've jiggled the connections enough to make the circuit able to flow
  10. georgefrank
    83
    earth
    What do you guys think happened? What should I do? I dont want the 12V system acting up, I will no longer put strong current through it anymore
  11. rjparker
    10,533
    6,616
    The white cable may not have been plugged in properly. It comes from the battery. If so the power jump point would have been dead at the time. It is the advantage of understanding a diagram.
    So now its back to making a cheap grid tied inverter work without the grid?
    georgefrank likes this.
  12. georgefrank
    83
    earth
    No, that wont work, it needs to be off grid
  13. rjparker
    10,533
    6,616
    By the way, your 12v measurement in Ready should be 13.5 to 14.9 vdc and not less than 13v. Without the higher voltage the system is not charging.
    It could be the powerpath was there all along but the 12v battery was too low to Ready the car. That's why I was asking about things like lights and radio. If you somehow charged the +12 battery or it floated up in voltage the car may have then had enough voltage to Ready.
    Without a charging voltage the car won't run for long.
  14. georgefrank
    83
    earth
    What I found was the fuse connected to the 12V battery is taxed and possibly damaged, hence power not going to the front area
    Then once I wiggled it etc, it must've made that connection and the prius is working again
    I am so grateful the main inverter is maybe not damaged
  15. ASRDogman
    ASRDogman Senior Member
    7,832
    3,990
    It's probably overheated. You'll have to clean it very well and make it shinny....
    And also where it connects in the fuse box....
