fault codes
Discussion in 'Gen 2 Prius Main Forum' started by Mehmet alb, Apr 15, 2023.
  1. Mehmet alb
    Mehmet alb Junior Member
    77
    Turkey
    what do these codes mean ?what can I do. thank you very much
    #1 Mehmet alb, Apr 15, 2023
  2. PriusCamper
    PriusCamper Senior Member
    13,070
    5,306
    Pacific Northwest, USA
  3. Mehmet alb
    77
    Turkey
  4. Tombukt2
    13,444
    2,418
    I don't know them in English to text isn't in English I'm sure somebody will try and post it up in Turkish and you'll be good to go
  5. ChapmanF
    18,553
    B1421 is of no concern. That code is provided only so that a person can tell whether the solar sensor on the dash works. When the sensor works properly, B1421 will be present if the car is shaded or in darkness, and not present if the car is in strong sun.
    B1431 and B1441 both pertain to the air door (hava klapesi) that controls the mixture (karisim) of heated and unheated air. B1441 is an issue with that door's kontrol servomotor, and B1431 is an issue with that door's pozisyon sensor.
    B1443 is a similar issue with the kontrol servomotor that moves the door selecting which outlets (çıkış) deliver the air.
    Those servomotors can develop problems in the Gen 2 Prius (commonly, the problem really is the pozisyon sensor). Here is a thread with some information about those issues:
    No, that wasn't a mouse in the heater | PriusChat
    Explanations, and troubleshooting and repair instructions for those codes, can be found in the repair manual:
    Toyota Service Information and Where To Find It | PriusChat
