Loose tube near starter battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frank O, May 11, 2023.
  1. Frank O
    Frank O Junior Member
    35
    When we were checking the 12v starter battery at the back of our 2011 Prius today, we noticed a loose tube (see photo).
    Any help on what this is? Should the loose end attach somewhere? Thanks in advance
    Having trouble posting a picture. Image url is:
    https://i.postimg.cc/15wdykdG/tube.jpg
  2. RRxing
    RRxing Senior Member
    2,553
    1,826
    NEPA
    It is the vent tube from the 12V battery to allow any gases to be vented from the battery to the outside. This is to keep the gases from accumulating inside the vehicle. There should be a nipple on the battery where it attaches.
  3. ASRDogman
    ASRDogman Senior Member
    7,744
    3,962
    The nipple is hiding under the positive terminal assembly.
    You should be able to push it on without having to disconnect the positive terminal.
    If you can't, make sure you disconnect the negative first, and write down your
    radio stations! :)
  4. Frank O
    35
    Thanks. Here's a closeup of the positive terminal of the Toyota battery we just removed, which itself was a replacement for the original battery:
    https://i.postimg.cc/zfVrJJRd/battery-terminal.jpg
    Hiding in plain sight? Do all replacement batteries always have the vent duct?
  5. bisco
    52,244
    No, a lot of people put in non vented batteries and leave the tube hanging.
    It’s a safety issue . Some are concerned about it and some aren’t
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No. At least not exactly the same.
    And if it is an AGM battery, the vent should not come into play except in a
    catastrophic failure, like damage in an accident or a HUGE overcharge.
    I personally would not worry about it if the battery is AGM.
  7. ASRDogman
    7,744
    3,962
    Sorry, I didn't give enough information.
    Look on the SIDE, UNDER the positive battery cable.
    If it's not there, someone didn't tranfer it from the original battery.
    It looks as though that battery is a Toyota batter.
    You may have to go to Toyota and get the 90 degree angles plastic
    that plugs into the battery so you can attack the hose.
    I do see a plastic piece attached to the hose. So maybe it was broken off.
    And the rest is in the battery. At the Toyota dealership they should be able
    to show you a battery and where it goes....
  8. Tombukt2
    13,252
    2,393
    My battery do not have the vent tit. My ne HB battery no have vent tits I threw away the rubber tubes . Well they're in the junk pile anyway so the battery was reassembled the HV one with no vent tubes My AGM battery 12 volt has no vent tip no place to put it It's just isn't there so the tube is just standing there like this car.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    P.S. The 12 V battery in a hybrid does NOT perform starter functions like in a conventional car.
    So it really is not a "starter battery".
  10. RRxing
    2,553
    1,826
    NEPA
    Well, the car won't start without it, so...
  11. ChapmanF
    18,427
    We'll end up putting the word 'starter' in front of a whole lotta parts, if that's the criterion.
    CR94 likes this.
  12. bisco
    52,244
    I like “ready battery “
  13. ChapmanF
    18,427
    There's a not-ridiculous reason for calling it the starter battery: after all, the other battery is completely disconnected when the car's off, so this is the only thing around to supply juice to the button you push when you want to use the car.
    There's also a non-ridiculous reason for not calling it the starter battery: that term, to vast numbers of people, means a battery that has to supply high cranking amps to turn a starter, and if you go shopping for one of those, you'll get steered toward the exact opposite kind of battery from what works well in a Prius.
    Toyota calls it the auxiliary battery, so maybe it's good to just nudge people toward that official term for consistency (but maybe not by jumping on them for saying something else).
  14. bisco
    52,244
    Ya, that’s not gonna change
  15. RRxing
    2,553
    1,826
    NEPA
    It's the 12 Volt Auxiliary Starter Battery! :rolleyes:
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    It won't start without a LOT of other parts too.
    Your statement is worthless.
    But you really knew that already.
