This motherloving wheel bearing won’t come out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gino Veltri, May 11, 2023.
  1. Gino Veltri
    Gino Veltri Member
    413
    40
    Ok what am I missing here. I’ve just about destroyed the entire wheel bearing and dust shield pounding at this for three days. How does this thing come off? Tried slide hammer, that’s how it broke the bearing in two.Please help!
    F0E90168-3285-4FE5-8275-031836A22D4A.jpeg D0560BDA-4FAB-452B-AA4C-E9EDC73CA667.jpeg 1B8DD6A6-311E-4449-BD68-A263CDF555F7.jpeg 2DC820D9-7239-4BB6-B626-F907C051013E.jpeg
  2. Gino Veltri
    Gino Veltri Member
    413
    40
    I don’t even see how it supposed to come out
  3. Tombukt2
    13,291
    2,398
    It goes out the back where you took the four bolts out it comes out that way usually doesn't require very much tapping or anything where you go in the wrong way for a long time so when you go flip it over to take the four bolts out you have to flip it back over
  4. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    The first rule of brute force is that if it doesn't work, you aren't using enough.
    You may need to use fire and ice- use a torch to heat the knuckle (makes it expand) and cold water to periodically cool the inside of the bearing (makes it shrink) and enough of that will make the hammer strokes work better.
    Tombukt2 likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    These can be taken out in two minutes. It's all technique. Assuming you are replacing the hub assembly, not JUST the bearing, because the assembly is the way to go.
    Find two long bolts using the same thread as the bolts you removed. Thread them in from the rear on opposite corners and then beat them with a hammer to knock the hub out. Works for me every time. I learned my lesson the first time trying to use a slide hammer. My new way bangs 'em out like a champ.
  6. Mendel Leisk
    41,826
    Just to clarify: the holes are threaded, you screw in the bolts till they won't turn any more, then give them taps, then turn a bit more, then more taps, and so on?
    ColoradoCrow likes this.
  7. ChapmanF
    18,457
    Another technique I've seen mentioned, haven't tried myself but probably will if given the chance, is an air hammer sideways on the bolt bosses of the hub, get it to turn a little bit in the bore, loosen it that way.
  8. Gino Veltri
    Gino Veltri Member
    413
    40
    wait a min. so beating on the back side where the bolts were removed is not correct? But its the housing on the front that needs to come off...if i could get the thing to turn an inch (so the bolt holes dont align) then i could use the two screw method. But i cant seem to.
    now that ive beaten the whole bearing out theres not much to push against so ive been trying to pry it off between the housing and hub (where the dust shield is)
  9. Gino Veltri
    Gino Veltri Member
    413
    40
    im having a hard time following. So the 4 bolts i pulled were from the back, and ive been hammering on the back because the housing on the front needs to come off. Is this incorrect?
  10. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Can you post a picture of the backside of the assembly showing the holes lining up? Maybe the front as well?
  11. Gino Veltri
    Gino Veltri Member
    413
    40
    could i use the same bolts i removed (of the 4) ? i shouldnt thread them in all the way right? because that would hold the housing on that im trying to get off.
  12. Gino Veltri
    Gino Veltri Member
    413
    40
  13. Gino Veltri
    Gino Veltri Member
    413
    40
    and here is the back
    the bolt holes line up just as they used to , no movement at all. I know if i could get turn the front housing just a little i could use the "bolt trick" but without that turn it'd just be joining the two parts im trying to separate , right?
  14. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    PB Blaster works wonders...[​IMG] Use a lot then. wait 15 min...beat...then.wipe off and try putting it in the freezer for an hour. beat it again. Use more PB Blaster. I've had success with this over the course of a few days....in the meantime think of the $1,000 in money you saved yourself on his job once finished.
  15. Mendel Leisk
    41,826
    I'm pretty sure the whole thing comes out the way it went in, from the outside. Not that I've ever done this... :unsure:
    And yeah, if bolt holes of the knuckle and bearing line up, it'll need to be rotated to get anywhere, hammering from behind. @ChapmanF suggestion to air-hammer the ears to rotate?
  16. Gino Veltri
    Gino Veltri Member
    413
    40
    huh ive always wondered if penetrating oil is just a scam. Torches seem to be the deciding factor in any frozen bolt situation. Havent considered the cold factor though...cold makes metal contract..right?
  17. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    I see your logic. but Mendal made a good point. if you use longer bolts going in from the back and tap the bolts themselves it should help break them free. Thread a bit and tap away. repeat and keep going. It cant hurt and will direct to force through to the wheel bearing.
  18. Gino Veltri
    Gino Veltri Member
    413
    40
    right, i just wanted to confirm. The outiside being what i called front n all
  19. Gino Veltri
    Gino Veltri Member
    413
    40
    I see , this makes sense. Ill give it a shot!
  20. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    Yes. Cold makes the molecules "hold still" so contract. I agree on the pentrating oil...until I was in a similar situation working on an old truck and PB Blaster Saved the day....I'm a believer now that I suffered bloody knucklesmore than 5 times... Now I spray PB Blaster on the joints of what I'm working on the night before...then in the am 80percent of stuff comes right off.
