Troubleshooting overheating problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cegeddin, May 12, 2023.
  1. cegeddin
    cegeddin Junior Member
    72
    22
    Oxford, NC
    I'm just seeing this. I will work on it.
  2. cegeddin
    72
    22
    Oxford, NC
    The Aisin water pump was definitely faulty...but figuring out how to get ahold of Aisin to replace the part is proving really challenging. Think I will be going with whatever Napa has next.
  3. ASRDogman
    ASRDogman Senior Member
    7,398
    3,857
    Some things are best to get "local", so if there is a problem, it's easily taken care of.
  4. cegeddin
    72
    22
    Oxford, NC
  5. Mendel Leisk
    40,924
    Yeah "almost" failing on all 3 inside walls, and cylinder 1/2 wins the race. The EGR passages in the intake manifold tend to clog sequentially, with cylinder one leading. This is without fail what happens, when 3rd gen EGR is left to clog, somewhere between 150K and 200K miles.
    Thanks for the follow up.
  6. cegeddin
    72
    22
    Oxford, NC
    It at least seems like I am working on this before it is a complete disaster though.
    I've got the head back from the shop and starting to get all the details lined up to put this car back together again.
    ASRDogman likes this.
  7. cegeddin
    72
    22
    Oxford, NC
    Hmm. Looking at the oil catch can threads now. Think I need to do that as well.
  8. cegeddin
    72
    22
    Oxford, NC
    Putting all this back together again is nervewracking as hell. The gasket masters guys make it seem so easy, but there's a lot of "and then just put it back together again" wordage that doesn't fit with the parts I have laid on the table.
    But, one step at a time. I took decent notes coming apart, so I think as long as I match a reassembly step to the notes of dissassembly (it isn't quite the same order exactly), it'll be fine.
  9. cegeddin
    72
    22
    Oxford, NC
    Got the car reassembled.
    Initially looked good. Got the temp above 200 and the fans kicked on and temp stabilized. Drove a couple miles to the gas station, and it seemed fine at first, but then started throwing p261b code. Looked and the coolant was empty.
    Put some in, got it back home but started getting hybrid system errors and the car just shut down. Found that the clamp on one of the hoses for the EGR hadn't been slid into place, and that was the cause of my coolant loss. Fixed that, put coolant in, and started the burping process. Car is now overheating and showing the check hybrid system warning light, but no new code from Torque.
    I'm guessing I may have fried the water pump again when the coolant drained out? Letting the car sit unplugged from aux battery overnight and going to take a look tomorrow. If it is still being funky, I'll pull it apart and take a look at the water pump and thermostat. I think the temp may have spiked into the 230/240 range before I got it shut down.
    On the other hand, I'm not getting any misfire engine codes, which I was getting before. So I think the head gasket replacement was a success.
    Back to the first problem, the overheating issue.
  10. cegeddin
    72
    22
    Oxford, NC
  11. rjparker
    9,841
    6,074
    Is this new? Inverter pump or inverter. Should be codes.
  12. cegeddin
    72
    22
    Oxford, NC
    Just pulled the water pump off. It definitely has a stiffness to it. Not completely locked up, but it doesn't really spin well either.
  13. cegeddin
    72
    22
    Oxford, NC
    p261b code.
    From some previous posts, at least one of the meanings of that is the water pump is not spinning as fast as the car wants it to.
    I'm going to take this pump back to Napa and try another.
    I'm worried that there's a reason beyond the car overheating that this would be my 4th pump. Though, it may be reasonable that my screw up with the hose on top of the EGR could have stressed the water pump out, maybe. So it might be if I get a pump back on there without overheating the car (or having the pump run full blast with no coolant in the car) that it could take care of the problem.
    I do need to test the thermostat, given my last overheat. Though I may just get a replacement. They are relatively inexpensive.
  14. cegeddin
    72
    22
    Oxford, NC
    What is great and worth celebrating is I'm not getting any codes relating to cylinder misfires, which I was getting before the head gasket replacement. So, yay. I think if I'm patient, I'll figure out why things are going kablooey and have a decent car.
  15. cegeddin
    72
    22
    Oxford, NC
    I've been focusing on the ?main? water pump, not the inverter pump, and watching the coolant temperatures spike there. I haven't really looked at the inverter pump.
  16. ASRDogman
    7,398
    3,857
    The engine cooling and inverter cooling are two seperate systems.
    You would get different codes for over heating if the inverter was overheating.
    I believe a new water pump and thermostat would be best.
    When you fill the system, GO SLOW!!!! Pour for 5 or so seconds, slowly, that wait 5-10 seconds.
    Continue this until you can fill to the "B" of the overflow tank.
    Of course it will take longer to fill, but you will get the air out and not have a problem.
    I believe filling quickly creates air pockets. Pouring slowly allows the coolant to fill all the pockets and
    push the air out.
    cegeddin, CR94 and Mendel Leisk like this.
  17. Mendel Leisk
    40,924
    The 2010 will have the coolant vent gizmo, which you open while filling, hopefully evacuates some of the air as you fill. Attached is the Repair Manual instruction.
    cegeddin likes this.
  18. cegeddin
    72
    22
    Oxford, NC
    Awesome, I hadn't seen the excerpt before, though that was the process I've followed.
    Really crossing my fingers that the problem was the pump just blowing air 'cause of that pipe. Some of the other threads I'm reading have some rather confusing looking processes for what else might be implicated in that p261b and why a pump might not be running well.
    I did look at the clip, and it seems to be fairly clear. The car did appear to do okay in the driveway in maintenance mode when the temp finally got up, the fans kicked on and cooled the engine off as expected. Wasn't until I got onto the road (which is granted a higher stress test on all fronts) that the pipe blew off the egr cooler that I had problems.
  19. cegeddin
    72
    22
    Oxford, NC
    Dammit. Got the replacement parts, but I can't get the bolt on the bottom engine side of the thermostat to thread. I don't know if it got overtightened last time so now after getting it off I can't get it back on or what. But damn, that's pretty bizarre and annoying and perplexing.
  20. cegeddin
    72
    22
    Oxford, NC
    Looks like it is messed up at the entrance of the bolt hole
