I'm getting a P3030 and a P0AC0 ... might 12V battery be to blame?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by blueprius2006, Jul 11, 2023.
  1. blueprius2006
    blueprius2006 Junior Member
    brooklyn, ny
    I am getting codes P3030 and a P0ACO. I checked my 12V battery and in a parked state, it is showing a reading of 11.8V. Might the battery be to blame for this? Any suggestions? Picture below. Thank you.
    52,334
    it's a small possibility. charge it up and see if it holds. if not, replace it.
  3. bisco
    52,334
  4. PriusCamper
    PriusCamper Senior Member
    13,004
    5,286
    Pacific Northwest, USA
    There's a chance it could be something other than a 12v, but until the 12v is fully charged or replaced, there's no way to find out.
    blueprius2006 likes this.
  5. Brian1954
    Brian1954 Senior Member
    2,385
    958
    South Central PA, USA
    No, the 12v battery probably will not cause those two trouble codes. The HV battery can cause those codes.
    #5 Brian1954, Jul 11, 2023
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Sorry. Wrong answer.
    The right answer is in post #4 above.
    A no load reading of 11.8 indicates that the battery has a charge of LESS than 15% and that can
    cause all kinds of problems.
  7. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    While it definitely is advisable to follow the advice in post #4, the 11.8 V shown in the opening post is not a "no load" reading. To get that reading on the MFD, the OP has to have had the car in IG-ON. Unless the battery drops further to 9.5 V (or in some cases below 10.5 V) on startup, it definitely will not "cause all kinds of problems."
    I can tell you from experience in a Gen 2 it is not uncommon for the 12 V to drop to 11.8 V on startup and I can assure all readers that it causes no ill effect.
    So unless contributors have solid evidence to support their claims, let's dispense with the bad information.
  8. Brian1954
    2,385
    958
    Codes P3030 and P0AC0 are triggered when the car is in "READY". When the car is in "READY" the inverter is supplying 13+v to the car. The 12v battery is being charged from the inverter at that point, so a 11.8v in the battery has no effect in triggering the two trouble codes.
    The two trouble codes are being triggered by a problem with the HV battery.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    Sorry I'm not perfect like you.
    I didn't look at the image in the post.
    And flatly stating without any qualifications that the 12 V battery can NOT cause that to happen is no more right
    than what I said.
    Lighten up a bit, please.
  10. Brian1954
    2,385
    958
    You misquoted what I wrote, which was
    "PROBABLY WILL NOT CAUSE"
    Now I will lighten up.
    #10 Brian1954, Jul 12, 2023
  11. dolj
    dolj Senior Member
    8,546
    4,341
    Yeah, no worries.
    I guess years of data collection and observation from actually driving this model doesn't count for anything.
    It would seem you have basic reading comprehension problems if you can't see the qualifications attached to my statement. Troll elsewhere.
  12. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Do you need any help finding the diagnostic workups for the above DTCs?
  13. blueprius2006
    brooklyn, ny
    Do you mean descriptions of the error code? No, I was able to look them up...
    update: It seems that it is not an issue with the 12V battery. An AAA tech came to look at the 12V He said the battery is fine but the hybrid system is not charging it properly.
    I was able to charge it up I believe by driving around and taking it on the highway for a bit (I'm rather wary of doing so given the state the car is in). Here are some update images below
    WhatsApp Image 2023-07-13 at 13.21.49.jpeg WhatsApp Image 2023-07-13 at 13.23.42.jpeg
  14. bisco
    52,334
    so now you have to address the codes
    Brian1954 and blueprius2006 like this.
  15. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Since there may be confusion, I will post the workups for whoever may need them. Page 66 of 165 (or HB 66) has the workup for DTC P0AC0 (and P0AC1 P0AC2 P0ABF): https://attachments.priuschat.com/attachment-files/2020/03/183963_Hybrid_Battery.pdf
    Here is the workup for DTC P3030 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/20zmw/cip3030b.pdf
    As Bisco kindly mentioned in post #3 above, DTC P3030 may be an issue with the high voltage sense harness tabs / connector or the HV battery ECU socket / PC board. Does the interior of the vehicle have any condensation or standing water?
    An example of what damage at ECU and harness plug can look like :
    [​IMG] [​IMG]
    Notice how pins 22 & 23 (bottom right) on the ECU socket have broken off and are stuck inside the plug on the right.
  16. blueprius2006
    brooklyn, ny
    Hi... yes, the harness is damaged. I was told the ECU was also burned out and needed to be replaced. Here is a picture the mechanic sent me. He said some of the pins are corroded.
