Where is the ECM located and can a layman get to it?
Discussion in 'Generation 1 Prius Discussion' started by StrangeAsAngels, Dec 4, 2014.
  1. HellOnAStick
    HellOnAStick Junior Member
    30
    South Lake Tahoe
    $7E8 $7EA
  2. Robert1
    Robert1 New Member
    florida
    $7E8 $7EA Same issue 2011 Prius 3?
  3. dolj
    dolj Senior Member
    8,526
    4,326
    Wellington, New Zealand
    You need to post in one of the Gen 3 forums.
  4. ChapmanF
    18,458
    Those aren't the trouble codes. They look like maybe the CAN addresses of the computers reporting the codes.
    Trouble codes all look like abccc, where a is a letter P, C, B, or U, b is a 0, 1, 2 or 3, and each c is any digit or a letter A through F.
    dolj likes this.
  5. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    You have 5 ECUs in your car. Which one are you looking for?
    Engine
    Hybrid System
    HV Battery
    ABS/Power Steering
    Airbags
  6. ChapmanF
    18,458
    Although the Gen 1 Multiplex Communication System diagram does show around nine ECUs depending on how you count, only one of those ECUs is called the ECM (engine control module). That one is easily accessed behind the glove box in a Gen 1 (for countries that drive on the right-hand side of the road, anyway), adjacent to the steering ECU.
