How to Program a New Key Fob for Full SKS Functionality
Discussion in 'Gen 2 Prius Main Forum' started by usnavystgc, Oct 29, 2013.
  1. L P
    L P New Member
    Spokane
    Signed up to the forum just to say THANK YOU!!!
    Tried three times, then had to replace the battery (what a pain to remove those tiny screws!) in the old remote and then worked! Bought part 89994-47061 from Lithiatoyotaparts
    Thanks!!!
  2. stu4084
    stu4084 New Member
    Russellville, AR
    Hi all. I know there is a sticky thread on how to program a new smart key FOB. However, that only works if you already have one that currently works.
    I bought this car and it came with one key, it works in the slot and starts the car but not working to remotely unlock the doors.
    Bought a new SKS key and went through the procedure, however after getting into programming mode and I hit the lock/unlock buttons the doors wit just continue to cycle the locks as long as I hold the buttons down. When I let off and hit the lock button it cycles the locks twice. Any ideas?
  3. jimolson
    jimolson Member
    155
    58
    Indianapolis, USA
    Thanks for such a clear and thoughtful write-up on this.
    Today (November 2023) I learned that there are two Toyota part numbers for full SKS keys: 89994-47061 refers to the version of the full SKS key with a blank metallic key. 89904-47011 is the same full SKS key without the metallic key.
    Both these keys have the slot for inserting the metallic key into the housing.
    Consistent with Toyota's capitalistic bent, the version of the fob without the 20 cent metallic key is ~$20 cheaper.
    Jane Manderscheid likes this.
  4. craig biggio
    craig biggio New Member
    I have read all 37 pages.
    2008 SKS silver key and non-OEM duplicate advertised to be programable/new.
    Once I have put the car into SKS add mode (indicated by only one lock-unlock cycle), I always get TWO lock-unlock cycles after pushing both button on the new FOB. It doesn't matter if I try the new FOB first or old FOB first, or the seconds between the various steps, the new FOB always triggers two lock-unlock cycles, indicating that the process has failed. Indeed, the FOB does not work.
    Was I sold a bad key by everyone's favourite online book seller, or are there any other work arounds? I've tried the many flavours of button pushing in this thread and am at the several dozen of trials stage of grief.
  5. Jill H.
    Jill H. New Member
    SC, USA
    Where did you get the extra fob - from the dealer or online?
  6. Jim&Bini
    Jim&Bini New Member
    I went through these instructions for reprogramming a new replacement fob for my 2004 Prius and it took me a few times. In my case, for part B step 9 I had to try it twice for the programming to successfully complete. Thank you for these clear, detailed instructions
  7. Prius05IV
    Prius05IV Junior Member
    MN
    I wanted to add to this thread the fact that I purchased a new unused generic key fob for $50 (that is physically identical to a silver logo fob without the silver logo) and successfully programmed full sks functionality. took a few tries but I finally did chicken dance correctly.
  8. oldstock79
    oldstock79 New Member
    US
    *** What was the solution to this problem?******** Bad keyFOB or was it too many keys already assigned? - If it's too many keys- how do we delete one OLD key to make room for the new one??
  9. borgestes
    borgestes Member
    83
    74
    New York
    key1.JPG Happy to report that this amazon fob programmed correctly. I was concerned because my one good fob has a short or stuck button so I didnt think it would do what it was supposed to do but it did and I am happy about it. I found this fob shop down the street and called them on the phone, without hesitation they quoted 250 dollars. I saw something on reddit about pop a lock wanting 100 bucks to program, I called them and they quoted 450.00. I was like are you loco? This one programmed both the car and the locks function. hopefully it continues to work properly. 60 bucks cant beat it.
    Horseflesh likes this.
  10. Sami200pk
    Sami200pk New Member
    Oslo
    Hi
    I tried to changed the shell of my Prius fob with locked button broken at the circuit but after changing the shell fob didn't work at all. Before changing the shell fob was working with SKS and locking with remote.
    Now without remote working I can still start the car with key in the caset. So question is, can I program a new key with current circuit in fob not working ?
    What are my options here please help
  11. NewFan
    NewFan New Member
    Check you have put this IC in a new case.
  12. dolj
    dolj Senior Member
    8,384
    4,271
    Wellington, New Zealand
    That's an RFID chip and the car won't start with the fob in the slot without it, but it is a good idea to check that that was not overlooked.
    However, Sami200pk said the lock button on the circuit board was broken, so changing the case will not fix that.
    The short answer is no. If you can get the buttons responding and the fob working normally, then you could make a second copy of the fob using the chicken dance.
    If you have no (fully) working fobs, you are in an "all keys lost" situation. mr_guy_mann covered the options in this post here.
  13. Tjb44
    Tjb44 New Member
    SF Ca
    I tried this chicken dance to program an ebay fob for a 2009 but it didn't work. I even changed battery for good measure. The only thing that worked was programming it using techstream obd2. Fairly easy and straightforward.
  14. caddydad
    caddydad Junior Member
    Vancouver, WA
    I did the chicken dance on my '06 prius and it took several tries on Procedure A, finally working when the door opening was quicker. And, believe it or not, but I got Procedure B on the first try! Thanks for posting this!
  15. xw20_driver
    xw20_driver Junior Member
    76
    39
    PNW
    I just purchased my used 2007 Prius Touring. It came with only 1 smart key. I'd like to get a second smart key and try to add it on my own. Getting the key blank cut is not a priority. How do I know which generic smart key to buy and which to avoid? Are the ~$20 ones off Aliexpress functional?
  16. xw20_driver
    76
    39
    PNW
    I tried to add a smart key MOZB31EG using the method I found posted by "Igor" on youtube which is the familiar insert old fob 5x, open door 6x method. I have an OBD2 scan tool with advance functions to perform immobilizer and smart key functions. Both methods failed. I get the dreaded 2-1 flashing key dash light that might be related to the replacement key's "4D" transponder chip. I'm thinking the 4D chip may be blank and has to be cloned off of the master key using a special cloning tool. Trying to understand how the transponder chip comes into play with aftermarket smart keys. Is there a source for a transponder chip that the Prius is compatible with? I found some references to 4D67 and 4D69 chips. My car is a USDM which should be using a 312Mhz smart key.
  17. Horseflesh
    Horseflesh Junior Member
    30
    Pacific Northwest
    Well, I really pooched this.
    My car came with one fob -- black, no logo. I cannot even tell if it is OEM, or aftermarket. However, it DID have SKS functionality.
    I tried programming a new 3rd party key (black, no logo) that was referenced a few pages back. I got START/STOP functionality working.
    But when I tried to add SKS functionality I failed.
    And, somehow, I REMOVED SKS functionality from my original key! I am sure I made some kind of error in button presses on old vs new fobs. Oops.
    The original key button lock/unlock works, start with the fob in the slot works, smart unlock on approach and keyless ignition does not work.
    The new key only has start/stop.
    Ideas??
    Ack!
  18. gdowdy3
    gdowdy3 Junior Member
