2022 Bolt EUV Initial impressions
Discussion in 'GM Hybrids and EVs' started by jerrymildred, Sep 10, 2022.
  1. bisco
    52,362
    it actually worked out. i just put $500. down on an red LT with mandatory driver assistance, comfort and convenience packages.
    $33k-11k tax credits - about 8k trade in nets to 14k + about $1,500 ttl = $15,500. out of pocket.
    supposed to be here oct./nov., now i don't have to try to figure out what's wrong with the prius, other than it's a gen 3 engine.
    i wanted a premiere, but because the cancelled order was an LT, gm wouldn't allow the change.
    the person who cancelled bought a leaf.
  2. Mendel Leisk
    41,873
    This is a Bolt, right? (y)
  3. bisco
    52,362
    toyota just came out with $7,500. off bz4x to make up for tax credit loss. i just got an offer:
    $44,000. less toyota $3,000. discount = 41k. - 11k in toyota and tax credits = $29,000. net
    not bad, but i like $22,000. for the bolt
    jerrymildred likes this.
  4. bisco
    52,362
    correct
  5. Trollbait
    12,668
    Wonder what the deal on that Leaf looked like?
  6. hill
    8,912
    Once Bitten Twice Shy
  7. bisco
    52,362
    idk which one they bought. they told the chevy dealer they couldn't wait and bought the leaf.
    i just got an email from nissan. leaf s for 30k or lease for 24 months, 4k down and 200/mo.
  8. douglasjre
    douglasjre Senior Member
    2,202
    736
    Null, NL
    Compression damping too soft, rebound too slow. What are the people on bolt forum doing about that
  9. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Learning to speak whatever language you are speaking??? ;)
    GSK and bisco like this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Actually, I think you might fins it more comfortable than the PiP. As I recall, my EUV is way better than my PiP, but having the Pime in between might throw off my assessment a little.
    Oh my!! No battery thermal management at all. What were they thinking? That battery doesn't even have a fan like a PiP or a Prime. I think you chose well. Hope you like yours as much as I like mine.
    It feels to me like both compression and rebound are a bit under damped. Tends to pogo a little after the right kind of bump, like on poorly executed bridge transitions.
    douglasjre and bisco like this.
  11. bisco
    52,362
    thanks jerry,
    i haven't been this excited since i ordered the pip in 2011. now that that's done, it's time to start researching solar. i'm going to drop a post in your thread, with a few questions.
  12. bisco
    52,362
    is that the suspension you're talking about?
  13. douglasjre
    2,202
    736
    Null, NL
    Jerry, the bolt has no cooling for the battery? I gotta know because I pound my foot to the floor often and need cooling.....
  14. douglasjre
    2,202
    736
    Null, NL
    This is proper terminology to describe suspension. You are just knowledgeable. Max McAllister at traction dynamics in georgia and Dave Moss in California can give you training.
    fotomoto likes this.
  15. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    I'd seen OPD written out a few times recently here at PC, I think the part that caught my attention and probably disassociated the acronym for me was the part about using it in reverse. @jerrymildred
    I wanted to make sure I understood what was being described and it took a while to find it written out in the bolt forums.
  16. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    Bolt has battery thermal management, he was referring to the Leaf
  17. bisco
    52,362
    bolt has liquid cooling thermal management to be specific, as did volt
    jerrymildred and hill like this.
  18. jerrymildred
    11,517
    14,157
    Tampa, FL
    Yes, that's what he was talking about. I don't think it's bad, but it's neither a sports car nor a limo.
    As mentioned by a couple people, it does have active liquid cooling. It's the Leaf that STILL has no cooling of any kind. We all know that heat is the battery's biggest enemy and Nissan gave the car no defense against it other than throttling the charge rate or the propulsion power when the battery gets hot.
  19. bisco
    52,362
    nissan added liquid cooling to the ariya. not sure why they aren't upgrading the leaf, they aren't cheap!
  20. Trollbait
    12,668
    Are they going to even continue with the Leaf?
