What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. BlackPriusCv
    BlackPriusCv New Member
    Oakland
    I would like to install red floor lighting. Red doesn’t mess with your night vision, but allows you to see things well enough at night. It also does’t highlight dirt or mess.
  2. NyQuil
    NyQuil Junior Member
    30
    2016 Prius c
    Added a winch to pull out some machines for a move....yeah I'm gonna need to brace that wire guide but it worked!
    Roqu3 likes this.
  3. TipsyTurvy
    TipsyTurvy New Member
    2017 Prius c
    If you were buying a C and planning to do some stuff to it, what year would you go for? I was pretty set on a '19 LE because it was the last model offered in the states, but I noticed that it seems like the 2017 has the meanest face with the black accents on the vents.
    Also, I wanted a four, but does the trim really matter for the base? It seems like people are snatching up ones, are they swapping the engine?
  4. Leadfoot J. McCoalroller
    8,043
    7,520
    Pennsylvania
    2018 Prius c
    The 2018s and 2019s are fantastic just for the factory LED headlights.
    "mean face with black accents on the face" probably means a One or Two trim, otherwise there would be fog lights in place of the black accents.
    Be careful with the fours- some have an optional 16" wheel package. When you get that option the turning circle is WAY wider.
  5. TipsyTurvy
    2017 Prius c
    Compare the 2016 and the 2017. See how the 2017 has a different lip design from the 2016 below. Are these the stock LED foglights?
  6. Leadfoot J. McCoalroller
    8,043
    7,520
    Pennsylvania
    2018 Prius c
    I don't think they ever did LED fog lights in the USA models.
    The headlights in the 2018 and 2019 are LEDs, but every other lamp in those cars is incandescent.
  7. Robert Eldridge
    Robert Eldridge New Member
    West Sacramento, CA
    2017 Prius c
    Looking to install the same brace on my C this weekend. Curious to know what the torque specs are supposed to be? The instructions that came with the brace are in Japanese and I didn't see any numbers listed.
    Thanks in advance.
    -Robby
  8. Jumpedinthepriasus
    Jumpedinthepriasus Junior Member
    46
    Ct
    This looks awesome, definatly going to try something similar
  9. Jumpedinthepriasus
    46
    Ct
    I Upgraded to 6.5x 15" and have had far less of the freeway swerve, Lowering the car + Stiff coilovers also helped a lot
  10. Jumpedinthepriasus
    46
    Ct
    Can you post a link to this dash kit by chance
  11. NyQuil
    30
    2016 Prius c
    Wheel spacers, fender rolled (looks ok, my first time) and air bag helpers in the back
  12. Jumpedinthepriasus
    46
    Ct
    Finally did the 1NZFXE > 1NZFE Cam swap, Will make a post about this shortly
