Digital Rearview Mirror, Dealer Install?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Moonlight92, Oct 11, 2023.
  1. Moonlight92
    Moonlight92 New Member
    san diego
    2023 Prius
    XLE AWD-e
    My 23 Prius doesnt have this and i dont want to do 3rd party. Can the dealer add it on? Anyone try?
    TGrracie and otatrant like this.
  2. otatrant
    otatrant Active Member
    331
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    It is an interesting question. You can always ask some dealers. You might also check out the thread...
    Digital Rearview Mirror - No such thing
    From what I have read and seen on this site and others I am guessing it will cost around $2k for parts.
    Hammersmith outlines the parts needed in his post.
  3. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, don't try to do this upgrade OEM-style; just too expensive and disruptive for the car. There are plenty of aftermarket versions that will do 98% as good a job for <25% of the price. Only difference is you will need to glue a camera to the rear window instead of it being integrated into the liftgate.
    otatrant likes this.
  4. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    I install a Wolfbox G850 as dash and digital rearview mirror.
    Is a cheaper option and cover the issue to the small rearview mirror.
  5. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    looks great? How much? Did you install yourself or pay a shop? Wireless /wired?
  6. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    Back view is much bigger and better than the orignal mirror.
    It's $150 on Amazon right now.
    It's wired but I was able to install it myself.
    I also add a usb type A power adapter so I don't have too use the type C or 12V ports.
    I was able to hide all wires and adapter behind the rearview mirror casing.
  7. Argyros
    Argyros Active Member
    274
    141
    2023 Prius
    Actually, it's only $ 129 now on Amazon- make sure you click on the $ 20 coupon before going to cart, but go get it!
  8. Buschfeuer
    Buschfeuer New Member
    2023 Prius Prime
    XSE Premium
    @srwax How well does the mirror work on a bright sunny day? Thank you!
  9. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    So far it's been working great under bright sun light.
    No issue while driving and front/back recording is good enough to read license plates clearly.
    Buschfeuer likes this.
  10. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    Did you have the Toyota digital rearview or are you comparing it to the standard mirror? I have the Toyo digital rearview but really want front and rear cameras that don't cost a fortune.
    Where did you put the rearview and how did you run the wires?
  11. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    My limited didn't have the digital rearview mirror but I did test drive one that has it.
    The bazel on the Toyota digital mirror are huge and the viewing size are small compare to G850's 12" display.
    I mounted it with the 3M tape that the camera came with at the top of rear window.
    No drilling or mounting rack require but I do have to pull the frame robber out to tuck the wire in.
    Reset of the wire can be tuck in to the passenger side frame and hide in the casing on the front window.
    With the type A power adapter it use the connector from under the front window casing
    So no wires laying around and it don't need to occupy any of the type C ports.
    deev, Serenity Now and Buschfeuer like this.
  12. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    Cool - thanks for all your input!
  13. Buschfeuer
    2023 Prius Prime
    XSE Premium
    @srwax Do you know if the rearview camera connection into the screen is a regular analog composite video input? I want to use a different rearview camera that is already installed and uses analog composite, and I'm hoping the screen supports using any analog video input of my choice (with the proper composite to 3.5mm plug of course). Thank you!
  14. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    This is a simular cable that's use with my rearview mirror.
    You can check and see if it will work for you or maybe you can find a adpter cable
  15. Hammersmith
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    (I assume you're asking about the main infotainment screen and not a screen built into a rearview mirror.)
    Absolutely not a standard composite cable going into the infotainment screen. They use a proprietary 3 or 5 channel connector for the video feeds. That being said, it's possible the video format is compatible if a new connector was spliced on. But there would be some trial and error needed as I don't think the channels are labeled in the Electrical Wiring Diagram. Toyota says successful repairs to the video cords would not be guaranteeable, so they advise replacement instead of repair.
    If you want, I can take a picture of the connectors tomorrow. I've currently got my passenger door harness out which has the male and female versions of the connector(I've got the Panoramic View Monitor option).
  16. Serenity Now
    Serenity Now New Member
    United States
    2024 Prius Prime
    Great post and outstanding job with your upgrade. Does the Wolfbox include the garage door buttons? I wouldn't want to lose those on my XSE.
  17. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    The Wolfbox doesn't include garage door buttons. However, I attached it over the original mirror so I still able to use those buttons.
    Serenity Now likes this.
  18. Serenity Now
    United States
    2024 Prius Prime
    Thank you!!
  19. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
    @srwax great job! Would you show more pictures on how the wires are routed from the back to the front? I am a bit confused now. thanks.
  20. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    Here are a few more pictures.
    You can pull the black robber out of the trunk frame completely because it's not glue.
    Once it's out, you can tuck the camera wire into the trunk frame and follow the ceiling frame gap to the center concel.
    Gwyd, deev and otatrant like this.
