CAN bus settings.
Discussion in 'Gen 2 Prius Audio and Electronics' started by ALCRO, Nov 22, 2023.
  1. ALCRO
    ALCRO Junior Member
    28
    Croatia
    Hello,
    Few days ago i buy 9inch android head unit that goes on MFD place.
    And i have trouble connecting can bus box to work so that i can have climate control on my Prius 2 gen.
    Is there any solution for this?
    I place the resistor between 9 and 10 pin.
    But still no fan control for climate.
    Here are few pictures.
    I have no more idea. I like the screen but its pain to play with heating only in steering wheel.
  2. ALCRO
    ALCRO Junior Member
    28
    Croatia
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,430
    1,485
    NJ-USA
    I don't know your Android unit at all, but the Gen2 Prius doesn't use CAN network for the MFD or climate control.
  4. ALCRO
    ALCRO Junior Member
    28
    Croatia
    Its aftermarket Head Unit. I'm not sure how can i get climate control to work. I see in few posts that people need to put resistor and that climate works but it works on a navigation OEM screen and my Head Unit is replacing the OEM navigation so i don't have heating controls.
    Any suggestion how to wire it or what to check?
    Thanks in advance.
  5. black_jmyntrn
    black_jmyntrn Senior Member
    1,289
    336
    2013 Prius Plug-in
    Which radio did you purchase?
    I am planning on getting this one, it says and shows the a/c screen and HV battery screen.
    https://s.click.aliexpress.com/e/_DBcwp5p
    Can you link to the one you purchased?
  6. ALCRO
    ALCRO Junior Member
    28
    Croatia
    Sorry for late replay, ill link radio later this evening when i come from home.
    After around 6 months i still dont have AC controls and HV battery screen. But i think seller sold me wrong cable. because from original navigation screen i have 2 connectors and on wiring harnest from android headunit i have only one connector that i can use. And if my android head unit is connected and working, i can connect original navigation screen and i can control AC only with one connector plug in. So i guess i get wrong wiring. But didnt have time to dissasamble it for the 25th time.
  7. ALCRO
    ALCRO Junior Member
    28
    Croatia
    Here is the screen shoot from seller, dont order from him. He didnt help at all just stall, a eventualy issue a refund and i get 60euros of refund.
    And i order those cales and i think they are wrong, on the label it said RAV4 and Camry
    If anyone have right cable for prius 2 gen il be happy to know :D
