Jumped prius opposite polarity and now the car is completely dead. What should I do?
Discussion in 'Gen 3 Prius Technical Discussion' started by SuperOmar, Dec 17, 2023.
  1. SuperOmar
    SuperOmar Junior Member
    Arlington, VA
    I have a 2015 prius with 250k miles. I accidentally jumped the car with opposite polarity from the fuse box under the hood. The car is completely dead now, when I try to turn on the car now, the only thing that I see on the dashboard is the door and engine check light.
    I looked through the fuse box under the hood the following day, and I found a few burned fuses which I replaced. However nothing changed. The dashboard still doesn't turn on and absolutely nothing happens when I push to start.
    I decided to tow the car to the nearby Toyota dealership however they couldn't figure out anything.
    What do you guys suggest me do?
  2. PriusCamper
    PriusCamper Senior Member
    12,303
    4,999
    Pacific Northwest, USA
    Pretty sure that means you have to replace your fuesable link... Not sure what else... Maybe @ChapmanF know?
  3. ChapmanF
    17,710
    Go through its pockets for loose change?
    (other ideas....)
    If you see the door and check engine lights, it's only mostly dead.
  4. SuperOmar
    Arlington, VA
    Thank you for your response. Do you mean that the auxiliary battery (12V) is dead? or the car as whole is dead?
  5. SuperOmar
    Arlington, VA
  6. ChapmanF
    17,710
    Have you visually inspected the fusible link yet, as described in the linked "other ideas"?
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    Pretty dang sad that a dealer can't sort this out.
    The initial troubleshooting can be pretty simple and may just be tracing the 12v.
    Verify the battery terminals have 12v.
    The fuse box should have a stud/nut connection where the (+) cable from the 12v battery fastens. Make sure you have 12v there. If not, something between the stud and battery terminal is open. Often there is a high amp fuse or link in that circuit, sometimes mounted on the + post of the battery.
    Often, (but I'm not a Gen 3 person) there is also some type of high amperage fusible link between that stud and the rest of the fusebox.
    You just need to determine where the 12v is lost, assuming the fuses did their job and protected from any major electronics getting smoked.
    Yup....the 2015 Prius (+) battery terminal cable has a 140 amp fusible link/fuse in the vertical section next to the battery, covered by the red plastic. May want to check that. If it's bad, it may require replacing the entire piece. You would think the car would be completely dead if it were open. With the dash still having a couple lights, it would make you think the problem lies somewhere after the battery cable/fusebox stud, but you just never know.
    #7 TMR-JWAP, Dec 20, 2023
  8. ChapmanF
    17,710
    Post #3 has a link with details on checking / replacing that.
  9. SuperOmar
    Arlington, VA
    I have another prius that is also generation 3, I moved the fusible link from the dead car to my other prius. The fusible link works just fine. I hope that this is a good way to confirm that it is in working condition.
  10. ChapmanF
    17,710
    Taking apart two cars' underhood fuseboxes to move the 125 amp internal fuse from one to the other sounds like maybe the single most difficult possible way to test that ....
  11. SuperOmar
    Arlington, VA
    I believe that I misunderstood what the fusible link fuse is. I just looked it up on priuschat and this is what I found. Is this the correct one?
  12. ChapmanF
    17,710
    That's the one I was thinking of. Is it the one you swapped?
  13. SuperOmar
    Arlington, VA
    No I swapped a different one. Do I need to remove to top half fuse box in order access it?
  14. ChapmanF
    17,710
    If you look back at the link I posted a week ago, that thread has a lot of information on how to get access to that. It's also something I would try to just test with a multimeter first; there are some ways you can test that without taking the box all apart, and that's a lot less work.
  15. SuperOmar
    Arlington, VA
    I was able to confirm that the fusible link is the blown out. I bought the fusible link for the dealership and tried to remove the top half of the fuse box to reach it however I was not able too. I was able to fine a bypass diagram on priuschat and followed the steps however still no change.
    What do you suggest me do?
    Thanks for your help
  16. ChapmanF
    17,710
    If the 125 amp fuse is blown. replace it. There is a thread linked in post #3 that shows how.
    After that, perhaps other fuses may still need to be checked.
  17. SuperOmar
    Arlington, VA
    I tried following the steps in post #3 however it is super difficult to remove the top half of the fusebox. So I tired bypassing the 125 amp fuse by using a diagram posted by @rjparker in another thread but the dashboard is still only showing the engine check and door light.
  18. rjparker
    9,846
    6,078
    I believe the right way to replace the 125a link is to remove the whole box which has big “christmas tree” connectors on its right side going into the sheet metal. I have never blown or bypassed that 125a link but that style bypass was used by another member and worked until his bad connections failed.
    As Chapman says there are always other fuses blown as well. In that box and in the interior fuse box. If a bypass was tried with a wrong sized fuse it will blow as well. There are other fusible links in the engine fuse box that some fail to check. There is a fuse at the 12v battery.
    Other common mistakes: Checking fuses by pulling them out and not returning the fuse to the right space.
    People will pull the hybrid battery orange disconnect and fail to perform the final slide engagement.
    It is possible the 12v battery is too discharged to start.
    It always requires two Ready attempts after disconnecting the 12v battery, which is sometimes needed to clear codes.
    #18 rjparker, Dec 31, 2023
  19. A.J
    A.J Junior Member
    Worldwide
    Is there any thread on how to remove the box?
  20. rjparker
    9,846
    6,078
    If I found myself in this position I would let a dealer fix it as the best solution. DIY I would spend quality time with the $25 TIS system searching for a procedure or TSB that may or may not exist.
    There are threads that show the end result of prying and tugging but to my knowledge no one has posted Toyota information on how to do it. Based on the fact it has two large push in clips going into the driver's side sheet metal, I would assume you would need to access that area by removing the wheel and liner or possibly the headlight assembly.
    Note two big clips on the side
    Bottom view with some kind of positioning receiver, a latch and a view of mounting bolt holes.
    Even if it's out and the cables are managed somehow, the top half of the fuse box has to be separated from the bottom half. That might be possible with the fuse box remaining in the vehicle. Possibly with the two side clips disconnected.
    If a dealer or trusted independent was available, I would have it towed and ask the mechanic or my hybrid guy to change it. I would first verify every other fuse and fusible link to save an extra hour of labor.
    Pulling all of those parts could easily lead to more damage or fuses installed in the wrong spots.
    Worse case, if I were 200 miles from a dealer on a Sunday, I might hack a bypass to get it going along with replacing any smaller fuses/links. I would then severely chastise the kid for agreeing to help jump his friend's 2015 Ram 1500. Wait a minute! His name is AJ and he routinely hides his profile location!
    The good news is almost everyone who has done this to a gen3 has come out of it without blowing ecus or electronics.
    Lesson I learned from other's mistakes: Always use a polarity checking lithium jump box (kept in the car) or change the 12v battery if a Prius has a bad 12v charge. Some learn best from personal hands on experience.
    #20 rjparker, Aug 8, 2025
