I have a check engine light and Pulled P1121 and P0121 error codes.
Discussion in 'Gen 2 Prius Main Forum' started by Kaptainkid1, Jan 3, 2024.
  1. Kaptainkid1
    Kaptainkid1 Active Member
    308
    247
    Los Angeles
    I can't not fix these problems for a week and want to know if I can drive the Prius for a couple days maybe 30 miles. Will this damage the car?
    SM-A536U ?
  2. Tombukt2
    13,291
    2,398
    Those are TPS sensor codes basically a voltage issue what happens when you drive the car? Does it drive park drive away when you're ready then I would say yeah you can drive it until you can't if the voltage spikes and ruins the TPS or any of that goes on then the car may or may not run may run in a limp home mode only to get you home so on and so forth me personally I'd be driving the car till I wasn't or I'd hop on my Aprilia scooter or any other of the five vehicles here but generally I would drive the Prius I'm driving one right now with the Christmas tree lit up and at random literally almost no brakes but you never have no brakes and a Prius you may have limited. So I would say drive on You should be getting to fix it probably before it completely stops working.
  3. Kaptainkid1
    308
    247
    Los Angeles
    I found this YouTube video on fixing the P1121 issue. It says I need to change Coolant control valve. Is this correct?
    Also has anyone used this replacement part sold via Amazon. Maernz brand?
    Can you recommend a brand part or link with a creditable replacement.
    As for the P0121 TPS sensor seems to be some I can clean? I read one could brake clean the throttle body and MAP sensor this may fix the problem. Will try cleaning 1st. If that doesn't work replace the throttle body?
    So is the P0121 throttle body TPS sensor is failing? So toyota did not make TPS sensor for the Prius? It seems I can not find any info or part number..
    Thanks,
    Screenshot_20240103_160532_Amazon Shopping.jpg Screenshot_20240103_160537_Amazon Shopping.jpg
    SM-A536U ?
    View attachment 250879 View attachment 250880
    View attachment 250881 View attachment 250882
    #3 Kaptainkid1, Jan 3, 2024
  4. Kaptainkid1
    308
    247
    Los Angeles
    Is this good part to replace the TPS sensor ? Screenshot_20240103_163518_eBay.jpg Screenshot_20240103_163505_eBay.jpg
    SM-A536U ?
  5. bisco
    52,286
    i haven't used them, but there is a lot of chatter here about bad counterfeit parts from non dealers
  6. Tombukt2
    13,291
    2,398
    Your best bet and what I found is my best bet is when I'm out at LKQ I take three or four of these things and just keep them in my box and then I put them in my spare parts at the house some of these TPS sensors and mass air flow sensors and that sort of nonsense can get quite expensive actually One of the mass air flow sensors on a Toyota I recently worked on was $189 I took one from another car at LKQ so I wouldn't have to buy a counterfeit so the person wouldn't be worried about spending $200 on a brand new Toyota part for a 19-year-old car so on and so forth plugged it up cleaned it plugged it up working great Guy couldn't be happier so there's always that If you're in it for the long haul and you're keeping the car and there's no ifs ands or butts then by all means spend the cash money and buy the original part if moved to do so.
  7. Frontporch
    Frontporch Active Member
    535
    121
    Nj
    I just replaced my coolant control valve. it was about $125 at the dealer for a Toyota part. Mine failed in a position where there was no heat in the car, but the car itself was not overheating. Also there was no coolant being put in the thermal tank, but I didn't care much about that.
    Had a Prius years ago, that the only symptom of a failed control valve was storing and retrieving coolant from the tank and I let it go for over a year, until ultimately I had to replace it to clear the CEL and pass NJ inspection.
    Don't buy aftermarket. My current prius had a failed Dorman unit. Seller installed it less than two years prior.
    Cleaning the throttle body is a maintenance item. Its not too much work and you just need to get at it with spray cleaner. Its on my list of things to do. The only thing it cost me last time was a throttle body gasket and some throttle body spray cleaner. I did lift the throttle body and put a small plastic tray under it to keep the muck from washing down. Hopefully cleaning that might free up any binding that can cause a bad throttle position reading. Just a thought on that.
  8. Kaptainkid1
    308
    247
    Los Angeles
    For the P1121 code I bought an OEM Coolant control valve. As for the P0121 code I haven't found what the correct procedure or parts to fix this Check engine light code. Can someone point to the right direction?
    SM-A536U ?
  9. ChapmanF
    18,458
    P0121 is indeed about the signals coming to the ECM from the throttle valve position sensor on the throttle body.
    The sensor is really two independent sensors, and two voltages come back to the ECM, called VTA1 and VTA2.
    This picture is from a Gen 3 repair manual (pic was already uploaded), but the Gen 2 details are not much different:
    The important thing to see there is that VTA1 and VTA2 are not identical voltages. VTA2 is always a bit more than a volt higher than VTA1, and the slope of VTA2 is steeper.
    (The picture showing magnets and Hall sensor ICs only is right for Gen 3. The Gen 2 sensor uses potentiometers. But it works the same, in that the two voltages have an offset and different slopes.)
    The ECM is always watching both voltages to make sure that they both are in range, and that they both have the right relationship to each other; any one of those checks not passing would mean something is wrong with the throttle sensor or the wiring. There are eight different trouble codes you can get, indicating just what check wasn't right.
    The P0121 code indicates a basic problem with the relationship between VTA1 and VTA2; it means the difference (VTA2 − VTA1) was smaller than 0.8 V or larger than 1.6 V, neither of which should ever happen.
    The code is pretty specific for the throttle position sensor itself, because some problem in, say, the wiring, would probably have shown up as one of the other P012x codes that are based on simpler checks. A 2006 repair manual pretty much says for P0121 to go right to replacing the throttle body.
    Kaptainkid1 and Brian1954 like this.
  10. Kaptainkid1
    308
    247
    Los Angeles
    Replacing the whole Throttle body? We don't have a cheaper option like replacing the Throttle body TPS sensor? This is where I found mix information and the whole Throttle body seems expensive and an over kill.
    SM-A536U ?
  11. ChapmanF
    18,458
    I don't think Toyota will sell you the sensor except already attached and calibrated to a throttle body, or allow one of their dealers to try that. That might not mean you can't try yourself, if you find the sensor somewhere.
  12. Kaptainkid1
    308
    247
    Los Angeles
    So what do people do? Replace it with a new Throttle body? I see a whole bunch of used Throttle body on ebay.
    Is installing a Throttle body new or used plug and play? Will it just work if its a functional part?
    SM-A536U ?
  13. ChapmanF
    18,458
    Should be plug and play, yes.
  14. Kaptainkid1
    308
    247
    Los Angeles
    Junkyard here I come..
    SM-A536U ?
  15. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    Odd that the sensors aren't sold separately. Are they mounted in some peculiar way that would have made replacement difficult?
    In this thread:
    throttle position sensor | PriusChat
    there is a post that said cleaning the throttle body fixed the sensor problem on one car.
    Frontporch likes this.
