SE add footwell lights from higher trims
Discussion in 'Gen 5 Prius Accessories and Modifications' started by purplePriii, Dec 12, 2023.
  1. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Thanks
    50% brightness when the car is being driven, lights in both front and rear?
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Prices for the parts I listed a few posts ago:
    82998-24290 - $1.44+$2.56 S/H (package includes 10, you'll need 4 of them)
    https://www.aliexpress.us/item/3256803154035818.html
    82998-12690 - $1.44+$2.56 S/H (package includes 10, you'll need 4 of them)
    https://www.aliexpress.us/item/3256803154784444.html
    90980-11918 - $4.19 (you'll need 2)
    Female Connecter Housing
    81080-33290 - $13.96 (you'll need 2)
    Lamp Assembly | Part #8108033290 | Toyota Auto Parts
    20AWG wire (a few bucks if you don't already have some laying around
    An open barrel crimper if you don't already have one ($10-$30 depending on quality)
    The pretax total cost worked out to be $8 for the terminals, and $36.27 for the Toyota parts(if you buy enough other parts to get to $75 for free shipping - maybe some wiper blades, oil, or filters). So $44.27 total for the parts, plus some wire and the crimper if you don't already have one.
    edit: Oh yeah, this is only for the front footwell lights. It doesn't include anything for the rear seats.
    #22 Hammersmith, Feb 7, 2024
    wrtboy168 and Lantaral like this.
  3. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yes. They aren't particularly bright to start with, and I said <50% because I'm pretty sure it's really in the 30-40% range. But it's impossible to know exactly unless you've got access to the code. The lights are pointed towards the toes of your feet, so you'd never notice them while driving even during a pitch-black night. In fact, I was convinced they stayed off while driving before I started typing that, so I jumped into my car to confirm before posting. And I had just spent an hour driving home in the dark not an hour before and still thought they shut off while driving(until I specifically checked for it later).
    I don't have the rear seat lights installed yet, so I'm only talking about the front seat lights.
  4. wrtboy168
    wrtboy168 Member
    70
    28
    Northern California, USA
    2024 Prius
    i spotted a few other foot well light kits offered in aliexpress and mostly are for the highlander and camry. do the white connectors look familiar?
    Lantaral likes this.
  5. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Looks like a variety of JST connectors.
  6. wrtboy168
    wrtboy168 Member
    70
    28
    2024 Prius
    just need to find a kit that works with the prius le. hope someone can post a pic of the original harness where the oem foot well lights. maybe one of these aliexpress kits would have a connector that simply plugs in to play. :sneaky:
  7. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    From my reading of the wiring diagram, there isn't going to be a simple connector to plug into. The connectors that plug into the LEDs themselves appear to be part of one of the main wiring harnesses. On the XLE/LTD and the Primes, there are 4 wires that come out of either the Power Distribution Box Assembly or one of the junction connectors and they are immediately wrapped into the main harness. The 4 wires become 2 pairs which exit the main harness near the LED locations.
    To add lights to the LE, a person would have to run wires from the PDBA and junction connector to the lights(basically create a sub-wire harness) or bypass the stock way of doing it and tap into some other wires. The first way will give you stock behavior of lights(light up upon unlock, dimming once in D/R); the second way will either involve a manual switch or have cruder behavior(probably no dimming, just on or off).
    I'd be happy to be proven wrong, but the wiring diagram seems pretty clear. I'll attach them. The lights are on page 10(K27 and K28), with the wiring extending into page 11.
    Lantaral and wrtboy168 like this.
  8. purplePriii
    purplePriii Active Member
    275
    122
    I'm late to the party but I checked this weekend on the driver's side and it seems like a split with the bundle of wires that goes to the OBD port in mine. I have some pictures but not sure how clear they'll be if you want. It's a blue and red wire. There is tape on the split and not sure if that's how they split or what it is exactly.
  9. Eqcliu
    Eqcliu New Member
    SF
    2025 Prius Plug-in
    SE
    Sorry for reviving a dead thread, but any chance you can post the Toyota part number? (or does anyone else know?)
    Looking to add to my SE
  10. pramodhrachuri
    pramodhrachuri Junior Member
    30
    2024 Prius Prime
    SE
  11. Hammersmith
    2,315
    2,357
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    OEM part number is 81080-33290. Need 2. MSRP of $20.61 each, but you should be able to find them for $11 or $12 each during the upcoming Labor Day sale in a couple weeks.
    Personally, I always go OEM, but the choice is yours.
    Agent337 and soft_r like this.
  12. sknow
    sknow New Member
    Socal
    2025 Prius Plug-in
    SE
    FYI I couldn't find the harness on a 2026 SE. I think they took it out.
  13. Eqcliu
    Eqcliu New Member
    SF
    2025 Prius Plug-in
    SE
    Just installed colored leds from Amazon, viable alternative if you want a splash of color.
    The only thing that didn't fit well was the turning and locking mechanism, but nothing some 3M foam tape can't fix.
  14. JustADadNotChad
    JustADadNotChad New Member
    SF Bay Area
    2026 Prius Plug-in
    SE
    Just double checking that you found no harness. I also have a 2026 plug in Prius SE and would like to add this feature.
