Tanabe Strut Tower Bar & Under Brace
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Mksky, May 24, 2023.
  1. Mksky
    Mksky Member
    61
    35
    Los Angeles
    2024 Prius
  2. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    I installed a Cusco strut tower bar, two chassis under braces from "Mike Five Hundred", and a TRD rear sway bar on my 2013 Plug-in. They really transformed the car and maybe saved my life! A guy pulled out of a side road and I was able to avoid hitting him with a quick instinctual left-right-left of the steering wheel. No squeal of tires, no sliding. I was amazed and very thankful for having done the mods. And finally I had convinced my wife (who was with me) that the cost of the mods ("to make the car safer") were more than worth it. What might also have helped avoid a collision were the 16-inch Weds SA-15R wheels I bought in 2014. They weigh 14.5 pounds each, and improve the steering response and roadholding. All in all, a great combination of mods, and all to make the car safer (and way more fun in the corners!). :)
    It will be interesting to find out how much a strut tower bar and other mods improve the Gen 5 Prius which is certainly superior to my Gen 3 Plug-in as it was in stock form.
    #2 Christopher O'Brien, May 27, 2023
    wrtboy168 and Georgina Rudkus like this.
  3. wrtboy168
    wrtboy168 Member
    70
    28
    Northern California, USA
    2024 Prius
    Agent337 likes this.
  4. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Look what we have here….
    Agent337, wrtboy168 and Lantaral like this.
  5. Agent337
    Agent337 Member
    27
    Orange County, California
    2023 Prius Prime
    SE
    @RightOnTime Nice! Please let us know how the install goes and your impressions of the Tanabe Strut Tower Brace after you get some corners in.
    RightOnTime likes this.
  6. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    wrtboy168 likes this.
  7. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    We got some very bad news! The Tanabe Strut Tower Bar is a ‘no go’ for the LHD Prius in the States. The brake fluid reservoir does not clear the mounting bracket.
    Will K likes this.
  8. Blackat
    Blackat Active Member
    478
    339
    Colorado
    2023 Prius
    Limited AWD-e
    Bummer, I was looking at doing this.
    It's more like the bracket doesn't clear the BF reservoir...
  9. Agent337
    Agent337 Member
    27
    2023 Prius Prime
    SE
    Ah shucks, greatly appreciate the follow up, I'll keep an eye out for any updates/other options, thanks!
  10. Blackat
    478
    339
    Colorado
    2023 Prius
    Limited AWD-e
    Probably have to go underneath the car
  11. Will K
    Will K New Member
    2024 Prius
    I tried out Blitz Strut Tower Brace for my gen 5 and it also does not clear the brake fluid reservoir... Very disappointing.
    Looking forward to finding a fit where no trimming/additional modifications are needed.
  12. Will K
    Will K New Member
    2024 Prius
    There seems to be multiple versions of both the Blitz and Tanabe bars.
    I am talking about this one, with the two mounting points .
    I have yet to check the other Blitz bar, as it looks like it has 3 mounting points and an added angle
  13. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
    Ok I got the tanabe under brace for my 24 prime. I can confirm that the muffler makes contact with the brace. Not sure if the prime muffler hangs differently than regular HEV models (most likely).
    I had to add spacers to the muffler hangers and lower the muffler an inch or so to clear the brace.
  14. Blackat
    478
    339
    Colorado
    2023 Prius
    Limited AWD-e
    How does the car respond?
  15. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
    Don't know yet. Need more seat time. My goal was to stiffen the rear to make it better while towing (I have a hitch and tow dirt bikes). I'll report back after a while.
  16. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Where did you purchase that bar?
  17. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
    Modified Toyota parts. Took 6 weeks as they had to order from Japan.
  18. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
  19. jtchinoy
    jtchinoy Member
    Hayward, California
    2024 Prius
