OEM spare tire install
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, May 31, 2023.
  1. b0nd0710
    b0nd0710 New Member
    2024 Prius
    Yes, I'll update once I receive all parts.
    wrtboy168 likes this.
  2. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    My feeling as well.
    Can't see how a spare would fit under the LE's panel.
    Has anyone tried to fit a spare into the LE?
  3. Hammersmith
    Hammersmith Senior Member
    2,326
    2,380
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sigh. LE owners could try actually reading the thread. The problems and solutions are described more than once.
    The height of the cargo deck is determined almost completely by the white foam boxes. If you replace the foam boxes with the ones for the spare tire, it will raise the floor up and allow space for the spare.
    To do an absolutely perfect conversion, you also need a different trim piece and a new deck board, but I would hold off buying those until you see if the LE versions are good enough for the real world. The cargo mat or liner will also need to be replaced as the low floor versions have "wings" that won't work with the high floor.
    All of this has been described at least three times in this thread so far, and another couple of times in other threads.
  4. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    To be fair, searched this thread and the other thread on this topic.
    Found much discussion, but not a single report of someone having actually installed it into an LE.
    #124 Lantaral, Feb 12, 2024
    RoadPoppy and wrtboy168 like this.
  5. wrtboy168
    wrtboy168 Member
    70
    28
    Northern California, USA
    2024 Prius
    i have been looking at other spare tire alternatives and there is this ez spare which offers aluminum spare wheels as opposed to steel.
    Preferred: 165/70R17 (30065)
    Secondary: 125/80R18 (40075)
    EFS Adapter: G - 5x114.3 (G001S57)
    Hub Ring: 72.6 / 60.1 (Z17D)
    Nut: M12x1.50 (DST20A)
    there is a yt video explaining why the recommended spare is different than the regular oem tire.
    i like the idea of aluminum vs steel hence i think the ez spare could be a great alternative for the prius le. i would think perhaps carrying an aluminum spare (32.8 pounds) on long trips would be lighter than with a steel spare.
    Lantaral likes this.
  6. Mksky
    Mksky Member
    61
    35
    Los Angeles
    2024 Prius
    Do you think the XLE can install the lower version foam boxes from the LE?
  7. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    I don't see why not. The lower version is factory standard in Japan on all non-plugin trims. The high one is a dealer-fit accessory there. Exact parts list would need to be determined though.
  8. b0nd0710
    b0nd0710 New Member
    2024 Prius
    Prius LE spare tire reporting back:
    Overall, I would say the LE spare tire install was a success with minor caveats as Hammersmith has pointed out and a few updates as well:
    1. The LE has a different configuration for the the plastic trim that forms on the bottom of the hatch opening and where the deck floor boxes latch onto. Since the LE has a lower floor, those latching points are lower than in an XLE or Limited trim. The black plastic clips DO NOT reach down far enough. The left hand side foam fit is not great on the LE and there is play on the left side foam. Right side foam is snug and secure enough not to matter too much. However, the latching points are too far apart to reach for both foams on the LE trim. The foams are not as sturdy as I would prefer. However, the LE fit is snug enough with the spare tire installed to still function.
    2. The existing deck board is good for the LE. There may be minor dimension tolerances but its close enough. However, the carpet mat has wing extensions and there are loose flaps on the edges. Not a deal breaker at all, as I was able to fit battery jumper cables in the larger void on the left wing. The right wing is so small it honestly doesn't matter if it remains empty. There is small play. I was able to fit an umbrella on the right wing void.
    Also, there is a small gap if the board and carpet mat are shifted all the way up. You just have to make sure the boards are shifted to the lower edge against the hatch door and avoid the possible gap.
    I have not driven around enough to tell of there is any rattling noise or any shifting of the spare tire parts. I'll report back.
    PXL_20240225_213928838.jpg PXL_20240225_214701678.jpg PXL_20240225_215341490.jpg PXL_20240225_215452313.jpg PXL_20240225_215519269.jpg PXL_20240225_215648468.jpg PXL_20240226_003611744.jpg PXL_20240226_003716997.NIGHT.jpg PXL_20240226_003758149.NIGHT.jpg PXL_20240226_003914540.NIGHT.jpg PXL_20240226_003935197.jpg
    csp1971, zare34, Lantaral and 4 others like this.
  9. Hammersmith
    2,326
    2,380
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If you decide you really want the foam boxes to be secured to the rear, you can order part 64716-47170-C0(Cover, Deck Trim, RR) for $107.09. That's the XLE/XSE black plastic trim panel in the bottom of most of your pictures. Replacing that will raise the plastic tabs to the proper height for the clips to work. Totally up to you whether it's worth it. If everything stays stable(or you fashion your own longer clips), then it's probably not worth the extra hundred bucks. But if things start repeatedly shifting over time, maybe you'll decide to order one.
    The deck board for the XLE/XSE would stay stable for you because it has "hooks"(pic in post 67) that lock into those rectangles in the top left and right corners of the foam boxes(also the folds are in slightly different locations). I'm assuming the LE deck board doesn't have those or they're in different spots. But a replacement board costs around $220, so I don't know if it's worth it. Your best bet is to shape some heavy foam into matching blocks, then glue them to the bottom of your board in the correct spots. That should help stabilize things nicely.
    Overall, it looks like the fit is the same in yours as in those of us with XLEs or Limiteds. I compared the stripped down pictures from your car and mine(post 64 in this thread), and everything looks the same other than my AWD parts.
    I'd be willing to let you have my original deck board, but distance is a problem and shipping is cost-prohibitive because it's so large. I'm probably going to be in southern Oregon sometime in the next few months and would be happy to bring it along, but odds are that you live in SoCal and that would still be a long way away.
    Jerry G, b0nd0710 and wrtboy168 like this.
  10. I Throw 99
    I Throw 99 Junior Member
    28
    2023 Prius
    XLE AWD-e
    My parts for the spare should ship any day now. What is everyone doing with the old foam and kit that is being removed?
  11. I Throw 99
    28
    2023 Prius
    XLE AWD-e
    So my spare tire assembly kit is scheduled to arrive tomorrow. Cool. Except that I am currently on the side of a mountain road with a busted tire as I type this. Hit a pothole. Toyota is sending a tow, but wanted to tow me to the nearest dealer, which is over an hour from my home… and I am only 15 minutes away from home. Geez, thanks for nothing, Toyota.
    Incidentally, this is EXACTLY why I was buying the spare tire stuff, so that I didn’t get stranded on this mountain road. Hopefully the tow truck beats the snow storm that’s supposed to roll in in a few hours.
    Jeff606 likes this.
  12. LesPaulTomFL
    LesPaulTomFL Junior Member
    I can't thank you all enough starting with Hammersmith. You rock putting all this together so detailed and at significant effort and time investment on your part. THANK YOU! Thanks to everyone who contributed! What a great community! Great Thread!
    I brought a spreadsheet to the dealership today with all 9 items and i went in there saying "We need to solve this problem" of no spare tire option in US when purchasing a 2024 Prius LE in white. :cool: I showed them I was serious by bringing my checkbook......I definitely threw them for a loop. Such details and knowing exact part number for LE.......so here is what they came back with. :(
    My sheet was total retail random toyota parts site off the net. Total came in at $1345 allowing $150 for the T145/90D16 spare tire.
    They offered minor assistance with procurement - saving me maybe $100 by throwing in a jack from another car. I said nah, I need 100% of the parts on that list guaranteed new in box or no sale of car. I need a solution not a $100 kiss.
    They then gave me an invoice, with ETA of 10 days (so guarantee all parts available which is great) at a cost of $1719.83!
    :mad: WHAT? Are you kidding me?
    So my first question is where are you all getting these genuine toyota parts from?
    I ended up putting a deposit on the car because I got what I felt was the right price and no double dipping with huge dealer fees and forced warranties or whatever. I can back out at any time and ETA for the car is less than 2 months - about 45-50 days.
    Hopefully I can find this for cheaper that $1700 as I think I can get a kidney for that in South America. This is just silly expensive but I cannot see myself owning a car that does not include a spare tire. Period. So I hope there is a solution so I can get this awesome looking 2.0L Prius in my inventory as the Prime is flat out off the table. I would have went prime but with no spare solution that is factory quality it is no bueno for me. And I am only willing to bend over so far on the cost of the spare solution talked about here.
    I told them, "Please Don't Make Me By A FORD!" - not sure what I will do if that price of $1700 holds.......that's a tough nut to swallow after paying almost $30K for a car. This is a necessary piece of safety equipment in my mind. Bad move Toyota to not have an option for this.
  13. Mendel Leisk
    41,921
    The only thing that’ll wake up Toyota is $’s: if potential customers eschew cars without a spare, they’ll quickly reinstate them.
  14. LesPaulTomFL
    You are right, but I as one guy cannot affect others purchasing decision - so I am not standing around and waiting for that - I posted on Facebook that I am their Marketing Department's worst nightmare - and when I work and give up my effort and time just like the many who contributed here I like to help solve the problem for others as well.....so let's start off with the complaint I just filed with the NHTSA - (can't post links yet as I am a noob):cool: google them and file a general safety complaint - i did! I used a New car VIN from my dealer :p
    You all should follow suite here - the louder we are the more attention this issue will get.
    I am also considering a huge sign for outside the dealership (empty lot next store) saying "No Spare Tires Available Here" or some catchy marketing that we can all share and turn into a national campaign as this is not limited to Toyota - it is an epidemic in the industry and quite unacceptable if you ask me. If we want them to address it we need to become the "Squeaky Wheel".
    If I can get a 4' X 8' sign up in coming weeks I will also invite the local News Station for the unveiling and they might pick that story up., This is a good human interest story as many people do not even notice the car they just purchased was lacking this critical piece of safety gear.
    I am also looking into "Class Action" with my lawyer and see if we can form a class and sue based on additional losses incurred when you had a flat and had no spare option was factory available. Stay tuned on that as I will not qualify to be a class member but I will in fact bring forth the action in my name if possible. If not I will find someone who will be willing to be the face of that campaign but if you had additional losses (added expense of towing/lost time away from work, etc) and we can identify that loss we might have a case. I am sure there are many of those examples.
    Finally I am working to setup an online petition to get toyota to add spare tire options for all vehicles in the USA. Working on how to start this so I will post more on that ASAP! I will need folks to sign that if we expect anything to come out of it.
    Bottom line - I want to buy this 2024 Prius - and I slapped a down payment on one yesterday to show Toyota I am serious - but accepting delivery on that without a spare tire "Solution" - not likely.
    And I am not likely to bend over for $1700 on a do it yourself option either as all the liability for these parts, the procurement and making sure they fit right is on me. That is BS for a new car - not ideal in any way. This needs to be included as an option regardless of cost.
    And if this is an option offered by Toyota factory for a spare and not this "Do it yourself" option then I am good and my work here will be done. That will be the goal of my efforts to get a manufacture option as we are never going to win the fight to have one included - it seems cost are a factor even if it was only $500-$600.
    I am not willing to spend $1700 on a do it yourself spare option however I will spend unlimited amounts of time and effort on making sure Toyota knows I am pissed and feel they are screwing me over with no spare tire option on a $30K car! More to come ASAP and Thank you all for this outstanding thread!
    60spedteach21 and Mendel Leisk like this.
  15. I Throw 99
    28
    2023 Prius
    XLE AWD-e
    Order online from Lewis Toyota and have it delivered. I just got my delivered yesterday… about $700 total. Others have paid less from Lewis with various discounts. Shop around online at Toyota dealers and find the cheapest with free shipping.
    and thanks to hammersmith, it was a very easy install.
    LesPaulTomFL and wrtboy168 like this.
  16. Hammersmith
    2,326
    2,380
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Current prices for the parts: (3/1/24)
    Code:
     MSRP      Lewis    Part Number      Part Name                        Part Description
    $104.28   $ 72.09   42611-21280      Wheel, Disc                      spare wheel
    $ 97.20   $ 97.20   T145/90D16       Yokohama Y870B                   spare tire (price from TireRack.com)
    $129.81   $ 89.75   64997-47100      Box, Deck Floor, LH              left white foam box
    $211.58   $146.28   64995-47080      Box, Deck Floor, RH              right white foam box
    $ 18.47   $ 12.78   51931-10040      Carrier, Spare Wheel, RH         bolt that holds down wheel
    $211.58   $146.28   64778-47090      Protector, Spare Wheel           foam pad the wheel sits on
    $130.56   $ 90.26   09105-47020      Box Set, Jack                    tool kit w/small bag
    $154.90   $107.09   64716-47170-C0   Cover, Deck Trim, Rear           (LE) trim cover that contains the higher mounting points for the floor boxes
    $324.53   $224.38   58410-47040-C1   Board Assy, Deck, Spare Tire     (LE-sorta) replacement deck board w/ reinforcement
    $ 49.33   $ 34.11   51978-47010      Protector, Spare Wheel           (AWD) steel bracket that covers the HV connection
    $  4.05   $  2.79   90179-06274      Nut(price for 3)                 (AWD) nuts to hold down the bracket
    $120.00   $ 97.75   PT908-47235-20   All Weather Cargo Liner, Black   (LE) high deck cargo liner
    $120.00   $ 97.75   PT919-47230-20   Carpet Cargo Mat, Black          (LE) high deck cargo carpet mat
    Total Prices:
    $ 903.48  $654.64   Basic (needed parts + tool kit)
    $1382.91  $986.11   LE Full (includes different rear trim and floor deck board)
    $  53.38  $ 36.90   AWD extras
    $ 120.00  $ 97.75   (LE) High deck cargo liner or mat
    Lewis is not the only place with that level of discount, they're just the closest one to me that has it. Feel free to search around to find a parts dealer closer to you with the same 31% discount. Parts dealers on the same network as Lewis(autoparts.toyota.com) offer free shipping up to $200 on any order over $75. Because of the size of some of the components, you might need to break everything into two or more orders so that each has shipping under $200. IDK because I imported my parts from Japan before they were available in the US.
    The basic version price is what XLE/Limited owners need to buy and what b0nd0710 chose to do with his LE a little earlier in the thread. The LE full version price includes the extra two parts that the LE needs to make the conversion perfect. The other two lines should be pretty self explanatory.
    And just a personal note, I respectfully don't agree with the complainers that insist every car should have a spare. I believe 90%+ of current and future owners of smaller vehicles don't need and/or wouldn't use a spare if they had one. The bulk of those cars exist in built up areas where a tow truck and a tire shop are close at hand. And I don't think the 90% of owners should have to pay for the cost of the spare, the cost of the milage penalty the weight adds, and the opportunity cost of the lost cargo space just for the 5-10% of us that need/want a spare. I have no problem helping people that want to add one, but I'm not going to be an advocate to try and force any (IMO unneeded) change.
    Jerry G and wrtboy168 like this.
  17. LesPaulTomFL
    God bless all of you for that! I can't think about letting my teenage daughter drive my new car then have issues and not have a spare. I am going to enter the parts in at Lewis and check - THANKS for that. Seems like it will save me $1000 which is another awesome product of this thread - thank you all again!
  18. Mendel Leisk
    41,921
    I'd counter that Toyota should provide an optional kit, reasonably priced (($200~300 USD), for "the 10%", and design the area the spare resides in so you don't have to replace myriad parts. Do they even provide a scissor jack lug nut wrench now? They at least did that in gen 4.
  19. LesPaulTomFL
    I think I am going to qualify as one of those future owners of smaller vehicles and I am definitely going to qualify as a complainer - only because I am too busy to need another "Science Project" on my schedule so I can have the car I want with the safety features I want and many people I talk to think it should come with one as well, included, OEM. I am NOT going that far as there is $$$ involved.
    I support freedom of choice so the only change I am going to advocate for moving forward is that each manufacture be required "To Offer" a solution as an OEM option. I honestly think that solves both sides of the problem and those who don't need it great don't pay for that option. We do not want to force it upon anyone with regulations either so I would only want to make the manufacture have it available as an option.
    That way I don't have any responsibility for it or uncertainty around the solution using the right parts, it just comes with it for $1700 (Ouch) .
    We have all this safety sense and everything else - we should be allowed to have this without a science project incorporating 9 parts and me confirming everything is correct and available. That is purely Toyota's fault so I am looking to force the manufacturer's to provide an OEM option. That's all I want. And I fully expect they will rape me for it financially as they have already shown they will. Option may end up being $2100 with install whatever. What would my kid or my grandmom do if they were buying this car? Not this - I assure you.
    I fight for freedom of choice and I fight for the others who would never know what to do in this situation and I bet there are 20 cars out there without this comprehensive guide and "Do it yourself" solutions documented. We are very lucky to have the benefit of the work of Hammersmith and several others. (Sorry I don't have all the names)
    Great job but I bet every Mazda buyer, every Nissan buyer, insert brand here, does not have this.
    Prius owners are a tight group and this shows that. Other groups like mustang users maybe......do not know,
    And I am not sure what I do next is really going to be "Complaining" per say.........as opposed to rallying for change. I look to encourage these manufactures to "Do the right thing" here and that will either happen or it won't......but we will see and many times consumers do notice and actions speak louder than words. Let's see if I post this petition if folks are willing to sign it. That will show us how they feel on the subject for sure. And it will also send a clear message to toyota of North America in this case as well. It's in the oven...... :cool:
  20. LesPaulTomFL
    I was going to buy a used Gen 4 because it came with a spare - they just wanted to make too much on it. could not get there with the dealer. for me new was a better deal - they hold value very well as a car.
