Engine behaving strangely and popping hoses off intake manifold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by anonymous, Jan 13, 2019.
  1. ChapmanF
    18,316
    If you're impatient, you can look up the code in the Repair Manual (more info) and find its Confirmation Driving Pattern. Those are different for every code and some are simpler than others, which is why some permanent codes can stay around for a really long time, if your driving habits never happen to include that pattern.
    Once you complete the pattern and the monitor says it completed with a normal result, the permanent code should be gone on your next startup.
    xliderider and Paul E. Highway like this.
  2. Paul E. Highway
    Paul E. Highway Active Member
    206
    129
    Hawaii
    FYI my permanent PO441 cleared today, thanks to all for comments
    xliderider likes this.
  3. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Wasn’t so permanent after all!
    Paul E. Highway likes this.
  4. 419 Grease Monkey
    419 Grease Monkey Junior Member
    Houston, TX
    This.
    anonymous likes this.
  5. Mendel Leisk
    41,643
  6. 419 Grease Monkey
    Houston, TX
    yes, thats what i tried to post, thanks.
  7. Lares_Mat
    Lares_Mat Member
    199
    59
    It looks burnt rather to me, which could be, if the filter is made out of a light plastic mesh.
    This could be a good confirmation of an occasional back fire / small explosion in the intake manifold popping different hoses off it and burning the light mesh (maybe both - blowing ang burning it) ;)
    Mat
  8. B09
    B09 New Member
    Los Angeles
    thanks for sharing this. same thing was happening to my '15 prius two, replaced the EVAP purge valve and it's back to running smoothly!
    Brian1954 likes this.
